Another A/C problem
Old Jun 12, 2007 | 12:14 PM
shueman's Avatar
Default Another A/C problem
2003 Accord ~50K miles
Turn A/C on and getting only outside temperature air. Put gages on the low side and there seems to be enough refrigerant in the system. However, neither the low side and high side pipes are hot.
Compressor? <- if so, what are the chances of the condenser and evaporator getting hit with debris?
Thanks in advance
Old Jun 12, 2007 | 12:30 PM
methodical's Avatar
is the compressor kicking on at all?
i had a similar problem and it turned out to just be a relay that had gone bad.
Old Jun 12, 2007 | 01:14 PM
BluLude's Avatar
Default Re: Another A/C problem (shueman)
chances are slim, the compressor turns on right? whats the pressure on the low side
Old Jun 13, 2007 | 06:08 AM
shueman's Avatar
Clutch doesn't seem to be engaging.
Pressure ~60 psi.
Old Jun 17, 2007 | 08:51 AM
Westcoastnativ's Avatar
Default Re: Another A/C problem (BluLude)
I have a similar problem with my accord my. I had to replace the passenger side wiring harness that fits inside the fender well. Now my a/c compressor will not engage. It does runs when I test it with the battery. Where is the relay switch? How much did it cost to replace?
Old Jun 17, 2007 | 10:38 AM
YeuEmMaiMai's Avatar
Default Re: Another A/C problem (Westcoastnativ)
check this out
#15,#16
Old Jun 18, 2007 | 12:01 AM
Fl. Man's Avatar
That is definately either a short in the harness or your compressor died out.
Old Jun 19, 2007 | 03:58 PM
Default Re: Another A/C problem (Fl. Man)
The Harness is good. I wired the compressor to the battery(while the car was running) to test it and when I connected it to the battery it made the car shut off. I'am guessing I have a bad compressor?? Does anyone have any idea where to get a compressor with me having to refinance my car??
Old Jun 23, 2007 | 02:24 PM
NormanBates's Avatar
My AC had same problem I took it to my brother, Honda Tech., and he found that the valve on the high side pipe was stuck open. The pressure read good, but it was all air-no refridgerant. Take the caps off and listen for any leakage.
Old Jun 23, 2007 | 09:52 PM
fiveten's Avatar
Default Re: (shueman)
If you have pressure and the clutch does not engauge then you have an electrical system failure. Most of the time the a/c system can tell you what is wrong. Lets do a self diagnostic test.
1)Turn the ignition switch OFF.
2)Turn the fan switch OFF.
3)Set the temperature control dial on Max Cool, then push the mode control button to select Vent.
4)Turn the ignition switch ON (II).
5)Press and hold the recirculation control button.
6)While holding the button down, press the rear window defogger button five times within 10 seconds. The recirculation indicator blinks two times, then the self-diagnosis will begin.
6a)If there is any problem in the system after self-diagnosis is finished, the recirculation indicator will blink Diagnostic Trouble Code (DTC) 1 through 6. If there are any problems in the evaporator temperature sensor circuit, the A/C indicator will blink DTC 7 or 8.
6b)If no DTC's are found, the indicator will not blink.
Let us know what the code is, We can help you further....
Old Jul 1, 2007 | 11:28 AM
Ok. . . I tried the diagnostic on my car and did not get any codes/flashes.
nkkoanur
May 13, 2019 12:21 PM
tofuboi
Jun 10, 2007 05:32 PM
jdadams12
Jul 13, 2006 08:05 AM
llmwall
Sep 3, 2005 06:45 PM
91integraLSVTEC
Aug 22, 2005 08:18 PM
