engine
Old Jun 19, 2007 | 03:29 PM
jdm-cd5's Avatar
Default engine
hey guys i was wonding what engine is better to boost the f22b2 , the f22b or the f22b1 vtec i plan on using the drag turbo kit and building the engine up and boosting between 12 and 18 pounds of boost please help
thanks jdm-cd5
Old Jun 19, 2007 | 03:57 PM
Lubo_25's Avatar
Default Re: engine (jdm-cd5)
i wouldn't boost it...but that's just me
Old Jun 20, 2007 | 02:19 PM
jdm-cd5's Avatar
Default Re: engine (Lubo_25)
why may i ask
Old Jun 20, 2007 | 04:23 PM
Lubo_25's Avatar
dont get me wrong they make great induction motors and all...its just that they do come from factory NA...**** happens @ 500 hp whoever tells you otherwise doesn't know ****...the only advice i can offer is keep your boost moderate 300 horsepower is all you need for the street...
Old Jun 20, 2007 | 07:01 PM
JDM_Acccord's Avatar
f22b2 .. although your going to have to upgrade on your engine because it won't handle 18psi stock.
Old Jun 23, 2007 | 12:20 AM
Haccordclub's Avatar
Default Re: engine (JDM_Acccord)
Either one are boost friendly because of low compression. Id probably opt for the f22b2 so you don't have to worry about vtec. I mean I don't think its as big as a problem in sohc vtec that it is in dohc vtec. Turboing that much psi will require great fuel management and internal modifications. be ready to spend a lot of money.
Old Jun 23, 2007 | 05:33 PM
white99CF's Avatar
honestly from wut i kno id say boost the dohc f22b first off dohc not to say thas everything but u can definitely feel and see the difference once u get into higher numbers.Im doin a dohc head swap probably this weekend comin up cant wait to get rid of this lousy sohc. <y have 1 when u could have 2>sohc vtec motors
trytomake
Aug 15, 2009 03:09 PM
CB5F22A1
Oct 9, 2005 01:46 PM
killab443
Sep 9, 2005 07:14 AM
TenaciousC
Oct 7, 2002 06:23 AM
