idling....
Old Mar 29, 2003 | 09:48 AM
sailor's Avatar
Default idling....
anyone know how to fix the idle prob? its idling really rough at about 500 rpms when im a stop. i checked all the vaccum lines. wat else could it be?
Old Mar 29, 2003 | 10:07 AM
carolinaACCORD's Avatar
Default Re: idling.... (sailor)
what year and what transmission?
Old Mar 29, 2003 | 11:04 AM
spankey167's Avatar
Yea i have the same prob with my 92... checked all vacume lines as well... It tends to jump up to 1500 once in a while... Any Ideas?
Old Mar 29, 2003 | 11:10 AM
sailor's Avatar
Default Re: idling.... (carolinaACCORD)
97 accord 2.2 non vtec
Old Mar 29, 2003 | 12:32 PM
first off, are ya'll getting a check engine light?
second, it could be a number of things. since you've already checked your vacuum lines, lets go with the easy stuff first.
1. check your air filter, make sure it's not nasty as hell.
2. check your throttle cable, see if it's too loose. (they are a little loose stock)
3. ***adjust your idle with idle adjusting screw on the side of the throttle body*** (***this will probably fix it***)
4. intake air temperature sensor
5. idle air control valve
6. fast idle valve
BobLoblaw
Jul 20, 2019 09:11 AM
protopro88
Apr 8, 2011 03:41 PM
sun_zinc
Jul 13, 2008 01:19 PM
EMphaticONE
Jun 25, 2005 06:26 PM
RedStarGsr
Jan 7, 2004 12:01 PM
