Please Help Axle Problem Please Help
Old Mar 17, 2003 | 08:25 PM
SyN37's Avatar
Default Please Help Axle Problem Please Help
Ok I just finish doing a clutch job on my car. I tried putting in the passenger side axle. Here is the problem: It seem like the axle is too short like 1-1.5 inch short. if i push it in all the way then the axle nut won't reach and the abs sensor won't reach as well. If i put both side in at the same time then when i turn the steering wheel all the way to the left or right i can feel the bearing from inside the boot. I messed up 3 axle already (riped boot and bearing fell out). Wat is the problem?
Old Mar 18, 2003 | 04:45 AM
JimBlake's Avatar
Default Re: Please Help Axle Problem Please Help (SyN37)
Did you replace the axles? Are you sure you got the correct ones??
Old Mar 18, 2003 | 06:47 PM
SyN37's Avatar
yes is the correct one, please someone help me
rhdekhatchie
Mar 16, 2008 10:17 PM
jdm94accord
Jan 11, 2007 07:22 AM
JSpin
Mar 26, 2004 08:52 PM
tibbor
Nov 26, 2003 10:30 PM
