can't find this engine code/ need help
Old Mar 26, 2003 | 07:16 AM
kasper's Avatar
Default can't find this engine code/ need help
Background: I'm doing a jdm h22a swap in a 90 accord ex
Questions:
1) Check engine light is on but I can't find the code in any manuals. Could it be a tranny code??? The code is 3-4-3-6.... Does anyone have a clue what this is or possibilities that I could look into???
2) When the vtec kicks in it fells like it pulling slower instead of pulling harder, but it does kick in. The engine is ticking like hell which I know is the valves and I am adjusting them at this very moment. Could this be why the vtec isn't working right or is there something else I should look at?????
THANK YOU for any help in advance!!!
[Modified by kasper, 11:18 AM 3/26/2003]
[Modified by kasper, 11:19 AM 3/26/2003]
Old Mar 28, 2003 | 06:53 AM
dominate9's Avatar
Default Re: can't find this engine code/ need help (kasper)
Codes are read in patterns of long blinks and short blinks. Each code is separated by a pause. A long blink represents the first digit of the code and a short blink represents the second digits. So, if you get long long short , then the code is 21. If you just get short, then the code is 1. If you just get long, then the code is 10. Once you've figured out the code, go to http://www.crxworld.de/ecucodes.html
Old Mar 28, 2003 | 09:13 AM
ApexiAccord's Avatar
http://hondata.com/techecucodes.html
clik the above link this should help out. it explains the things you need to know for ob1
Old Mar 28, 2003 | 11:46 AM
kasper's Avatar
Default Re: can't find this engine code/ need help (dominate9)
I figured out the codes they are 34 and 36 but they don't exist
onesick97ek
Jun 3, 2012 08:05 AM
92TEGsrSC
Oct 17, 2003 02:42 PM
JD_B18CDX
Dec 11, 2001 12:17 PM
