suspension question: whats a bump rubber , noise protection sheet, Rubber spring protector
" * Comfortable ride quality is still maintained by using the OEM bump rubber and noise protection sheet.(available for most model) "
http://www.tein.com/htech.html
is the bump rubbber the same as a bump stop ?
whats a noise protection sheet?
what is a "Rubber spring protector "
"* Rubber spring protector sheet to prevent noise (most applications). "
http://www.tein.com/stech.html
Re: suspension question: whats a bump rubber , noise protection sheet, Rubber spring protector (jo
bump rubber = bump stop
rubber spring protector and noise protection sheet are probably the same thing, which is a piece of rubber a few inches long that wraps around the coil near the top of the spring. your oem springs should have one already...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philadd »</TD></TR><TR><TD CLASS="quote">bump rubber = bump stop
rubber spring protector and noise protection sheet are probably the same thing, which is a piece of rubber a few inches long that wraps around the coil near the top of the spring. your oem springs should have one already...</TD></TR></TABLE>
Ditto.
Ditto.
