Speedometer problem
Old Jul 16, 2004 | 08:53 PM
bodiez's Avatar
Hit the floor!
Default Speedometer problem
Car: 91 Accord Wagon
I have a speedometer thats just plainly not working. The blinking signal says the same. The speedometer sometimes works and sometimes just flatlines at 0mph. Also sometimes the engine check light comes on randomly. Its really weird. Where should i start to check stuff?
Old Jul 16, 2004 | 09:00 PM
madd's Avatar
Default Re: Speedometer problem (bodiez)
check all your wiring connections....could be your speed sensor.
do this:
https://honda-tech.com/zerosearch type in speedometer and search under the archived content in the accord forum. there are several results, as i have just searched for it. read through those to see if you can fix your problem. the search link is your friend!
maybe if it was a different color it would make a difference
Old Jul 16, 2004 | 10:12 PM
vroomvroomcivic's Avatar
i have the same problem, boughten speed sensors yes two, wasn't the problem, i just purchased a new cluster.....waiting for it in the mail, hopefully thats the problem, i heard that speedometers can go bad, we'll i'll see.
Old Jul 16, 2004 | 10:13 PM
fw190bvi's Avatar
Default Re: (vroomvroomcivic)
my speedo and odo went bad....a new cluster solved all that........
driving around and using gear combo + revs to calculate speed = teh win
Old Jul 30, 2004 | 09:38 AM
bodiez's Avatar
Hit the floor!
Default Re: (fw190bvi)
Sorry, whats a cluster
Old Aug 1, 2004 | 12:30 AM
Canonm7's Avatar
Default Re: (bodiez)
Your instrument panel, where your tach, speedometer and odometer are. Etc...
Old Aug 7, 2004 | 09:13 PM
SYTFU Tommy.'s Avatar
Default Re: (Canonm7)
mines is stuck at 20mph ne help on that?
Old Aug 8, 2004 | 07:34 AM
CaMiKaZi's Avatar
mine went bad. i bought cluster it wasnt it, it was the speed sensor.
Old Aug 8, 2004 | 07:49 AM
bodiez's Avatar
Hit the floor!
Thanks for replying, ill look at a speed sensor replacement
psm321
Nov 27, 2018 03:13 PM
howdydee2005
May 25, 2007 03:56 PM
poke708
May 17, 2005 07:26 PM
Accordloser
Jul 21, 2004 05:13 PM
olds_442
Jul 14, 2003 09:51 AM
