stripped bolt
Old Jul 16, 2004 | 03:27 PM
chochocho's Avatar
Default stripped bolt
hi all,
i am new to the forum and i own a 1993 honda accord.
I wanted to find out how to remove a stripped 17mm fill bolt for the transmission.
thanks.
Old Jul 16, 2004 | 03:34 PM
jakeiscool's Avatar
Banned
Default Re: stripped bolt (chochocho)
Try and use some channellocks and if that doesnt work i dunno what else to do
Maybe try and put a 16mm? socket on it?? I dunno
Old Jul 16, 2004 | 03:39 PM
pngfolife's Avatar
How badly stripped is it?
Old Jul 16, 2004 | 03:43 PM
EGPrelude's Avatar
go to SEARS and get the Craftsman stripped bolt socket set they have. It's only about $20 and i hear it works pretty good in getting stripped bolts out
Old Jul 16, 2004 | 05:31 PM
dockersguy's Avatar
I'm sorry, just for clarification when you say "fill bolt" do you mean the drain bolt underneath the car? I have a 92' Accord Lx and the only bolt similar to a "fill bolt" on the transmission is the drain bolt. It takes a 3/8 inch socket wrench without the socket and a breaker bar to loosen it. Are we talking about the same thing?
Old Jul 19, 2004 | 07:59 AM
chochocho's Avatar
Default Re: stripped bolt (dockersguy)
thanks for the replies, everyone. it is stripped very bad. i think i am going to have to drill it out and get a new "fill bolt" for the transmission. thanks.
Old Jul 19, 2004 | 08:00 AM
chochocho's Avatar
there is a drain bolt and a fill bolt in the transmission. the one i am talking about is the fill bolt, which is a 17mm bolt.
Old Jul 19, 2004 | 09:10 AM
dockersguy's Avatar
I never knew there was a fill bolt on the 93' Accord. I have a 92' Accord. I always drained it and then filled it thru the dipstick hole. Anyone else wanna chime in on this one?
Old Jul 19, 2004 | 09:30 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dockersguy &raquo;</TD></TR><TR><TD CLASS="quote">I never knew there was a fill bolt on the 93' Accord. I have a 92' Accord. I always drained it and then filled it thru the dipstick hole. Anyone else wanna chime in on this one?</TD></TR></TABLE>Manual trannys don't have a dipstick. They have a fill bolt, usually next to the axle.
Old Jul 19, 2004 | 09:42 AM
pngfolife's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chochocho &raquo;</TD></TR><TR><TD CLASS="quote">there is a drain bolt and a fill bolt in the transmission. the one i am talking about is the fill bolt, which is a 17mm bolt. </TD></TR></TABLE>
Have you tried heating the sucker and waxing it?
Old Jul 19, 2004 | 12:17 PM
iam7head's Avatar
Default Re: stripped bolt (pngfolife)
So it's the bolt's head is stripped or the thread is stripped?
grab a dremel, grind it a slot there and see if you can torque it out with big screwdriver.
Old Jul 19, 2004 | 12:26 PM
secksiman19's Avatar
Default Re: stripped bolt (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">So it's the bolt's head is stripped or the thread is stripped?
thats what i do to my stripped screws. should work if your a big strong man for a bolt too
Old Jul 19, 2004 | 04:44 PM
dockersguy's Avatar
Default Re: stripped bolt (secksiman19)
If you have room down there, get yourself a small pipe wrench and a pipe. Take the stripped bolt off this way. Pipe wrenches were designed to turn round things (rounded off bolt). Good luck.
spidermancivic
Aug 11, 2007 08:17 AM
HCivicSi23
Jul 14, 2007 11:15 PM
is3oo
Oct 4, 2003 01:48 PM
hellas
Jan 21, 2003 12:33 PM
