engine check problem
Old Jul 18, 2004 | 12:31 PM
daddycivic's Avatar
Default engine check problem
I have a 2000 accord v6. My engine check lite is on. How do i check for the code? Is there a thread for the code? Can anyone help me with this problem please. Thank you all that leave a reply.
Old Jul 18, 2004 | 12:53 PM
madd's Avatar
Default Re: engine check problem (daddycivic)
go to the search page then type in 'ecu codes' (or some variation...use your head). next select accord from the drop down menu (and don't forget to search both archived and current threads). i am willing to bet that you will find the info you so seek in one of them thar threads. NOW, if you are still unable to find your answer you then post. this is a pretty common topic some im willing to bet it's been covered a million times. if all else fails, go to autozone. they should be able to pull the code for you.
Old Jul 18, 2004 | 03:29 PM
Stryker's Avatar
Default Re: engine check problem (madd)
bring it to a local car shop like napa or auto zone and they'll check it for you for free.
if you have any aftermarket performance parts it might've triggered your primary or secondary O2 sensor.. or youe EGR valve might have gone whack.. get it checked out.
Old Jul 18, 2004 | 03:42 PM
madd's Avatar
Default Re: engine check problem (Stryker)
"bring it to a local car shop like napa or auto zone and they'll check it for you for free."
always wondered if they charged for that, thanks
Old Jul 18, 2004 | 03:58 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stryker &raquo;</TD></TR><TR><TD CLASS="quote">bring it to a local car shop like napa or auto zone and they'll check it for you for free.
Or you can check it yourself by jumping pins 4 and 9 on the DLC.
Old Jul 19, 2004 | 10:55 AM
daddycivic's Avatar
Default Re: engine check problem (Chiovnidca)
Thanks for the help. Got the problem fix.
Old Jul 19, 2004 | 01:45 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddycivic &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the help. Got the problem fix. </TD></TR></TABLE>
What was it?
Nathan007
May 23, 2008 08:25 PM
Guyana00
Oct 19, 2006 06:11 AM
OshkyCiv23
Oct 23, 2005 07:15 AM
redpeppers
Jul 22, 2005 06:07 PM
eh2
Jan 24, 2003 08:54 PM
