Engine Temp problems 4th gen
Old Jul 25, 2004 | 07:21 PM
accord4thgen's Avatar
Default Engine Temp problems 4th gen
90 Accord Ex
148,000 miles
Started up about a week ago the temp would rise pretty high (3/4 way up) on the temp guage. Sometimes it will go down if I turned on the heater and sometimes it will get hotter or cooler just on its own. When I shut off the vehicle the fan kicks in even on a cooler day or night.
I've noticed that it seems like only one fan might be working for the raditor ( the one right in front of the tranny)
What could be possible problems to cause this problem I am having?
Bad thermostat? Radiator? Coolant?
I'll probably just take it in this week but just curious if anyone might have had the same problem.
Thanks
Old Jul 25, 2004 | 07:33 PM
rc51rydr's Avatar
Default Re: Engine Temp problems 4th gen (accord4thgen)
Most likely its a bad thermostat...it just happened to me about 2 months ago.
Old Jul 25, 2004 | 07:39 PM
The_Todd's Avatar
Farts in the shower
Check your coolant levels, then your fans...turn on a/c to see that both turn on. If all is functional I would say thermostat especially since you are saying it goes down w/heater.
Old Jul 25, 2004 | 08:20 PM
cmrvi1's Avatar
Default Re: Engine Temp problems 4th gen (VRDrvr)
Both fans should come on at the same time. If only one fan comes on, it's probably bad.
Easiest way to tell if overheating is caused by the thermostat is to feel the radiator hoses. When the engine is at operating temperature, both hoses should be almost equally hot (actually the lower hose should be about 10-15 degrees cooler, but that difference is hard to tell at high temps). If the lower hose just feels warm, and the top one is hot, the thermostat is stuck closed.
Old Jul 25, 2004 | 09:01 PM
Thanks for the great responses. I will check out some of the things you guys mentioned. Appreciate the help
Old Jul 27, 2004 | 09:53 AM
dockersguy's Avatar
The different hose temperatures is a way to tell if your thermostat is working correctly. When I had a bad thermostat, the lower hose was mildly warm and the upper hose was hotter than hell. Turned out to be a bad thermostat(brand new Stant thermostat). So, I bought myself a Honda OEM thermostat the temperature needle has been rock steady ever since. Just to be sure, go ahead and check your coolant level, relays, fuses, and coolant temperature switches.
darmstro
Sep 2, 2010 05:59 PM
toyonda
Jan 26, 2009 06:06 AM
coupon
Jul 21, 2005 10:42 AM
petersayarath
Jun 16, 2005 04:59 PM
technine
22
May 9, 2005 12:47 PM
