will not start
Old Nov 28, 2004 | 04:52 PM
92greenwagon's Avatar
Default will not start
have a 92 accord witha 94 f22b vtec, the car is getting spark and fuel to the rail, the injectors are paulsing with a noid light any suggestions?
Old Nov 28, 2004 | 06:02 PM
JRtech72's Avatar
Default Re: will not start (92greenwagon)
some suggestions:
-How does the engine sound when you crank it? Does it sound normal
or does it seem to spin a bit faster than usual, like no compression?
-Are the plugs wet? Wet plugs indicate the injectors are pulsing. A noid light flashing only indicates the electrical part functioning of an injector circuit not the mechanical part. Low or no fuel pressure will not allow fuel to squirt in.
-Did you check all cylinders for spark, how does the spark look?
it should be brite blue and be able to jump a 1/4" plus gap.
Finally check to see if the timing belt didn't jump a tooth or more. Use crank pully and cam sprocket marks for comfirmation. You can also remove dist. cap for approximate cam location, but it won't be precise. A compression gauge can also be used to confirm valve timing is off. No cylinders should be under 100psi.
Good Luck!
Old Nov 29, 2004 | 01:49 PM
Default Re: will not start (JRtech72)
im getting 60 psi at turn key on the fuel, the timming if perfect
mushmash
Jun 5, 2018 02:04 PM
Maidumechanic
Feb 14, 2013 05:39 AM
drift2004
Jul 20, 2009 07:46 PM
SimplyTron
Feb 19, 2007 12:08 PM
93civicd16z
Feb 22, 2006 10:10 AM
