5th Gen Temperature Knobs Loose/Broken?
Old Nov 29, 2004 | 01:21 AM
Charri's Avatar
Default 5th Gen Temperature ***** Loose/Broken?
Well to be specific my hot/cold temperature **** is loose now. I cant seem to find out what happened. When I try to turn the **** know i feel there is no resistance and there is nothing turning except the **** except. Usually I would feel that I would be turning something sort of rough but now theres no resistance. Could it just be that the **** fell out of its joint or something? I hope I dont have to replace this whole set. What might be wrong?
Old Nov 29, 2004 | 01:23 AM
nizmo's Avatar
Default Re: 5th Gen Temperature ***** Loose/Broken? (Charri)
Its just the ****. If you pull it out, you'll most likely see whats wrong.
Not too expensive to replace either.
Old Nov 29, 2004 | 04:12 AM
brads94accord's Avatar
its probably just broken. you can order a new one from honda. they are really cheap. a shop gave me a new one for free, he had a huge box full of them
Old Nov 29, 2004 | 11:58 AM
EGPrelude's Avatar
if its broke, a new one is only $6
Old Nov 29, 2004 | 01:36 PM
smooth95's Avatar
yeah I think that little metal piece inside the **** probably broke
Old Nov 29, 2004 | 02:01 PM
madd's Avatar
Default Re: (smooth95)
its actually plastic, and super glue and shrink wrap worked wonders for mine im also cheap!
Old Nov 29, 2004 | 06:49 PM
Charri's Avatar
Default Re: (madd)
Found out it was the plastic covering the metal piece snapped somehow. I will stop by Honda this week to buy one. I need to defroster for my car or else I'm blind =[ Especially in the winter time
Old Nov 29, 2004 | 07:29 PM
just keep some needle nose pliers in the car to turn the **** lol...thats what i did for a little bit. the **** only fits on one way so there no need to worry about messing up where its suppose to be
Old Nov 29, 2004 | 07:35 PM
yardy8301's Avatar
Default Re: (brads94accord)
lol, i did that for a while too, or you can just use the other **** for both, or you can replace it since its only $6.
Old Dec 1, 2004 | 06:12 PM
Charri's Avatar
Default Re: (yardy8301)
Damn **** costs 10.95 at my Local Honda Dealership.
Old Dec 1, 2004 | 06:24 PM
sj993's Avatar
Default Re: (Charri)
You can get them here for $7
http://www.secureleadercom.com...block
Of course with shipping it'll be more so you're probably better off going to Honda.
Old Dec 1, 2004 | 08:02 PM
1994AccordSiR's Avatar
ill sell you one for $5 just im me @ amikej if your interested
Old Dec 8, 2004 | 07:52 PM
SCcorolla's Avatar
Old Dec 9, 2004 | 05:29 AM
KGAccord's Avatar
Default Re: 5th Gen Temperature ***** Loose/Broken? (dohcvtecguy)
the honda dealer i go to sells a little metal piece to slip over the end of the **** so it doesn't break. http://www.hondabarnnissan.com
Old Dec 9, 2004 | 10:49 PM
z168's Avatar
-pull the **** out
-put some super glue on the broken tip
-put a strip tie around the tip to prevent the **** from breaking again and also to reinforce it (use a pair of pliers to pull the strip tie to make it tight)
Immortal-Prelude
Nov 24, 2007 11:39 AM
xluben
Jan 16, 2007 06:17 AM
Black Raven
Dec 15, 2005 12:40 PM
hk350
Oct 27, 2004 03:45 PM
extracrunchie
Oct 2, 2004 02:33 PM
