Check engine light came on while driving?
Old Dec 18, 2004 | 09:31 PM
91EXRMANUAL
Guest
Posts: n/a
Default Check engine light came on while driving?
i was driveing along and the check engine light came up ..
i opend the hood , but the engine didnt do anything diffrent?
how do i turn off the light... do i need a laptop
Old Dec 18, 2004 | 09:46 PM
Carolina Fried Rice's Avatar
Default Re: Check engine light came on while driving? (91EXRMANUAL)
get a diagnostics done, its like 60$... but before you do that, make sure your gas cap is tight (believe it or not in some cases its the cause), then reset your ecu (disconnect battery for a few minutes) and see if light comes back on. If it comes back on, try to do the "jumper" trick. I dont know much about your model accord, 91 I'm assuming? But do a search and do your own diagnostic. If you cant figure it out, pay someone to test it. Good luck.
Old Dec 18, 2004 | 09:55 PM
91EXRMANUAL
Guest
Posts: n/a
Default Re: Check engine light came on while driving? (TSAF22B1)
http://www.obd-2.com/ will work?
TeamSumner
Sep 29, 2014 05:14 AM
Chadted
Honda Civic (2006 - 2015)
Jul 14, 2009 10:06 AM
93gsrhatchbrid
11
Mar 31, 2006 03:26 PM
ZeroGSR
Oct 7, 2004 04:57 AM
Preludegirl
Dec 3, 2003 08:14 AM
