HELP! Something is wrong!
Every time I make a sharp right turn, or simply drive in a circle (basically as long as the steering wheel turned to the right to the max) I hear this harsh, scourching sound, very similar to the sound as if the wheel is rubbing the fender on the drivers side, however, I put back my stock 15's and it still kept on doing it. I've inspected the wheel well with the wheels off and there were no rubbing marks what so ever. Also... what i noticed is that the sound comes when I am in gear, accelerating, as soon as I stop giving gas or shift into Neutral sounds stops. What could be causing it? Powersteering? Bad bushings? I know its not my wheel bearing or pads cuz I've just replaced them 2 weeks ago. Maybe belts? Cuz it does kinda sound like its coming from the belts area. Also when AC is on sounds seems to be getting louder. Any help would be appreciated. Thanks.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbowa »</TD></TR><TR><TD CLASS="quote"> They may be just a hair loose causing this sound.</TD></TR></TABLE>
My thoughts exactly. Just check the tension on your belts and tighten them up if they're a little loose.
"just a hair loose" what does that mean?
How do i check for tension? and how do I tigten it up?
Ohh yeah.. timing belt and water pump was changed at 90k... car is at 137k now.
Thanks.
Thanks.
by "just a hair loose" he means they might not have enough tension which is causing them to slip and make that noise. Tthe best way to check an adjust this is to get a manual. In there you'll find directions on where the lock nuts and adjusting bolts are and how much flex should be in the belts.
Or you can try running a search on this in the archives. You might find some instructions in there.
buch75
Aug 29, 2015 08:37 AM
RenX
Nov 5, 2009 04:03 AM
TypeRuz
Oct 26, 2003 06:38 PM
