Throwing a code 5 someone please help
Old Dec 31, 2004 | 09:19 AM
Superman137's Avatar
Default Throwing a code 5 someone please help
ok my jdm h22a is throwing a code 5 which is the mapping sensor I think and I'm wondering where is the mapping sensor located and if I unhook the sensor how will my car run and also where can I find one that won't cost me a leg
Old Dec 31, 2004 | 10:01 AM
Turbowa's Avatar
Default Re: Throwing a code 5 someone please help (Superman137)
What year H22? Most new honda's have the MAP sensor located on the top of the throttle body. You can get a new one at a dealer there not to expensive.
Old Dec 31, 2004 | 10:16 AM
Luisito825's Avatar
Default Re: Throwing a code 5 someone please help (Turbowa)
mine did that once or twice. i just jiggled it around and the code went away. I think haynes manual even says to move it around first, before suspecting its bad.
the map isnt attached to the TB its should mounted on the firewall.
btw your car will not run w/o the map.
Old Jan 1, 2005 | 10:03 AM
Default Re: Throwing a code 5 someone please help (ogbusboy)
well its a 93 motor and I took the sensor located on back on the intake mani aloose and it has stopped doing it so where do I find that sensor at and also need a o2 heater sensor I know where I can get that sensor from but what motor do I need to buy it for oh by the way its' the primary
efyou999
May 24, 2012 12:21 AM
sharky8513
12
Feb 5, 2005 08:25 AM
TEAM SL
21
Aug 23, 2004 04:04 AM
