rear coilover install problem
Old Jan 1, 2005 | 07:57 PM
jb.'s Avatar
jb.
Default rear coilover install problem
So my buddy and i put on the from apexi ws coilovers and we started on the back. We cant get the bottom of the factory strut off because of the bolt that holds it to the bushing. Is there a way to get it off without having to damage the bushing, or do i need to just replace it
Old Jan 1, 2005 | 08:00 PM
fw190bvi's Avatar
Default Re: rear coilover install problem (jbkiksass69)
very sommon on mchpersons for the lower bolt to sieze w/ the bushing and whatnot....happened to a guy i know, and they just had it pressed off, and got a new bushing
Old Jan 1, 2005 | 11:21 PM
syclone's Avatar
Default Re: rear coilover install problem (fw190bvi)
what car?
you can use a lot of wd-40 and an impact wrench..
Old Jan 2, 2005 | 01:25 AM
JonnySBeee...'s Avatar
if you are talking about the same bolt i am talking about, me and my buddy were working on his car installing Omnipower coilovers on his dc, we ran into the same problem, first we sprayed wd40 then we use a impact wrench like stated. hope it works, good luck to you.
Old Jan 2, 2005 | 07:30 AM
aZnAcCoRd02's Avatar
Default Re: rear coilover install problem (jonny05)
yeah wd40 and impact wrench takes that off, i ran into the same problem with mine too, if you dont have impact wrench, then a torque bar extended on to your wrench will help too. good luck with the install
Old Jan 2, 2005 | 02:45 PM
syclone's Avatar
Default Re: rear coilover install problem (aZnAcCoRd02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aZnAcCoRd02 &raquo;</TD></TR><TR><TD CLASS="quote">yeah wd40 and impact wrench takes that off, i ran into the same problem with mine too, if you dont have impact wrench, then a torque bar extended on to your wrench will help too. good luck with the install</TD></TR></TABLE>
if the bolt is seized, you have to use an impact.. using a breaker bar will most likely snap the bolt..
Old Jan 2, 2005 | 05:05 PM
CWestAccord's Avatar
Default Re: rear coilover install problem (syclone)
if that happens, get another bolt. either way, problem solved.
Old Jan 2, 2005 | 05:20 PM
syclone's Avatar
Default Re: rear coilover install problem (CWestAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CWestAccord &raquo;</TD></TR><TR><TD CLASS="quote">if that happens, get another bolt. either way, problem solved.</TD></TR></TABLE>
problem won't be solved.. you'll have a bigger problem.. if the head snaps off, the rod will still be in the bushings seized. then you'll have to drill the entire thing out which will be a major pain in the ****..
Old Jan 2, 2005 | 06:12 PM
jb.'s Avatar
jb.
thanks i got it off with an air chisel and pressing the **** out of it. we had to take the whole thing off
Old Jan 3, 2005 | 03:58 AM
rudeman85's Avatar
Yeah, thats a good pain in the *** there... I had to end up torching off the damn bolts and then torching the bushings out, yeah, burned the rubber and ****. I need to put new ones in soon cause I can feel a lotta play in the rear b/c of it. GOOD LUCK!~!
Brewbot87
Suspension & Brakes
May 8, 2014 04:12 AM
VietSpeed
Feb 13, 2009 06:36 PM
mikeunreal2
15
Jan 17, 2007 03:43 PM
VAsol
12
Jan 25, 2004 03:53 AM
Chronicsinners
Feb 20, 2003 12:20 PM
