Erratic speedometer - replace? lube? sensor?
Old Dec 30, 2004 | 06:42 AM
trimagna's Avatar
Default Erratic speedometer - replace? lube? sensor?
On my '91 Accord Wagon, the speedometer has become erratic. It usually reads accurately, but occasionally the needle bounces around, sometimes dropping to zero.
Can the bearing or cable be lubricated?
Should I replace the sensor?
http://oem.thepartsbin.com/par...S.JPG
Thanks,
- CarlD trimagna@yahoo.com
Old Dec 30, 2004 | 07:04 AM
slapout's Avatar
Default Re: Erratic speedometer - replace? lube? sensor? (trimagna)
Are you tripping a code? (it would be code 17) (flashing S on the dash?) It may be your vehicle speed sensor (VSS) going on you. Mine went out. I got mine from a place up in MA off Ebay for less than $50 bucks. That and a few hours labor to install. Good reference for this: http://www.cybertrails.com/~be....html
This guy has some excellent insight on Hondas! Fantastic resource.
Old Dec 30, 2004 | 08:02 AM
trimagna's Avatar
No, I don't think it is flashing any codes.
When your sensor failed, was there a time when the speedometer was erratic?
Should I consider the possibility that the wiring is being chafed? So far, it appears that there is nothing to clean or lubricate.
Thanks,
Pothole987
Honda Civic (2001 - 2005)
Aug 23, 2011 08:22 PM
mar7pau
Aug 29, 2010 10:34 AM
Rykertest
Jan 5, 2009 09:40 AM
guyuenvy
Apr 30, 2002 09:59 AM
