1990 honda accord won't start
Old 02-01-2005, 01:35 AM
squarehead's Avatar
Default 1990 honda accord won't start
The other day i was driving when my car started to sputter it sputtered at about five miles an hour to the side of the road, died and hasn't started since. anybody have any ideas why?
Old 02-01-2005, 04:19 AM
dirtracer's Avatar
Default Re: 1990 honda accord won't start (squarehead)
do you have power when you turn the key on? if not check the pos. lead to the fuse box under the hood.Could be loose happened to me.it's at the front right side when facing the car.
Old 02-01-2005, 06:08 AM
JimBlake's Avatar
Does the starter crank the engine & it won't fire up? Or does the starter NOT work? That makes all the difference for what kind of things we can suggest.
Old 02-01-2005, 09:26 AM
gen4acclude's Avatar
check your ground wires its happened to me also check the main relay, all ecu fuses
Old 02-01-2005, 01:01 PM
squarehead's Avatar
Default Re: 1990 honda accord won't start (JimBlake)
the starter cranks and the car sounds like it wants to start but just doesn't.
Old 02-01-2005, 03:41 PM
Goinfasterthanu's Avatar
coil or coil wire?
Old 02-01-2005, 11:13 PM
squarehead's Avatar
it cranks and wants to start it just doesn't i have read some troubleshooting info for the symptoms my car is having and it sounds like it might be the ignitor unit. what do you think
Old 02-02-2005, 04:02 AM
JimBlake's Avatar
Pull off a plug wire & check for spark. If the ignitor (or coil) are bad, you get no spark.
If you DO get spark, look for fuel problems. I don't know '90 Accords very well, what's it got for a fuel injection system...
Either way, you can also pull out the spark plugs & look at them. http://www.ngksparkplugs.com has a picture of spark plugs with different kinds of damage. Check it out & tell us what they look like.
Old 02-02-2005, 09:40 AM
supercreed2002's Avatar
I had the same problem!! But what went wrong on my car was the Ignitor. After I replaced this, the car fired right up.
Caleb
Old 02-05-2005, 08:58 PM
92acc's Avatar
Default Re: 1990 honda accord won't start (supercreed2002)
sounds like the main fuel relay to me also, i did my second accord myself very easy, if it isnt the problem it will be as the car gets older,
Old 02-06-2005, 10:59 AM
gator-dog's Avatar
i had the same problem two weeks ago and it was the igniter. i have a 91 accord i
Old 02-06-2005, 07:03 PM
Default Re: 1990 honda accord won't start (gator-dog)
Ignitor would be the problem... I've had the same problem. At first, I thought it was the fuel pump, ended up being the ignitor.
Caleb
Old 02-09-2005, 07:30 PM
bez
bez's Avatar
Default Re: 1990 honda accord won't start (dirtracer)
i hav a 91 accord lx and the battery fuse blown how do i fit it and what is the cause
Old 02-09-2005, 07:32 PM
bez
bez's Avatar
i hav a 91 accord lx and the 80 amp battery fuse blown how do i fix it and what is the cause
Old 02-10-2005, 03:54 AM
JimBlake's Avatar
Default Re: 1990 honda accord won't start (bez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bez &raquo;</TD></TR><TR><TD CLASS="quote">... the 80 amp battery fuse blown...</TD></TR></TABLE>Those big fuses generally have a couple phillips screws holding them in.
You still gotta chase wiring to find your short-circuit. You'll need a wiring drawing & a multi-meter.
Old 02-10-2005, 09:48 AM
hondadude's Avatar
Basic diagnose....turn on the key and listen for the fuel pump to run, and/or crack open the fuel fitting to check for pressure.
Turn the key on and check for power at the black/yellow wire at the dist.
Crank the engine and check for spark at the plugs.
This isn't rocket science and will save you money.......but if you just want to start throwing $$part$$ at the car; be my guest
Old 02-10-2005, 10:38 AM
weezo182's Avatar
Default Re: 1990 honda accord won't start (hondadude)
make a 2and post on cb7tuner.com if you havent already
Old 02-10-2005, 06:15 PM
blueaccord90's Avatar
Default Re: 1990 honda accord won't start (weezo182)
My first guess would be distibutor problems.
Just my 2 cents.
Old 02-15-2005, 10:56 AM
ddc
ddc's Avatar
I've got the same problem with a 1989 accord, carborated -- turns over but won't start. The spark plugs are sparking and I understand that the faulty relay problem only applies to fuel injected engines.
So it seems like the fuel pump/filter would be the next suspect? With a carborated engine, should I be hearing the fuel pump run for a few seconds when I turn on the ignition?
Old 02-17-2005, 04:59 PM
Default Re: 1990 honda accord won't start (ddc)
I thought the carb. honda's have a machanical fuel pump..... I might be wrong.
Caleb
Old 02-18-2005, 04:32 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddc &raquo;</TD></TR><TR><TD CLASS="quote">I've got the same problem with a 1989 accord, carborated -- turns over but won't start. The spark plugs are sparking and I understand that the faulty relay problem only applies to fuel injected engines.
So it seems like the fuel pump/filter would be the next suspect? With a carborated engine, should I be hearing the fuel pump run for a few seconds when I turn on the ignition?</TD></TR></TABLE>I think it's got an electric pump in the gas tank, but I'm guessing with a carburator there's no need for it to 'prime'. So if you want to verify the pump runs, you'll have to use a jumper to supply power from the fusebox or something? There probably IS a fuel pump relay. Can you find a wiring drawing for the car?
Old 02-18-2005, 05:47 AM
ddc
ddc's Avatar
Well it's fixed now. I think what happened is that a combination of cold weather and old plugs resulted in some serious flooding so that I lost compression. After new plugs and drying out the cylinders it started right up.
Thanks for the ideas.
BillPerry
11-16-2017 05:06 PM
Bienval23
08-18-2014 12:14 PM
hcivic99
06-05-2005 03:26 PM
JDMlyfestyle
22
01-09-2004 10:36 AM
hagrid
11-25-2002 03:27 PM
Quick Reply: 1990 honda accord won't start
