axel problem
Old Jan 23, 2005 | 04:48 PM
PleaseHelp's Avatar
Default axel problem
my left axel is in a servere stage according to a mechniac i have recently talked to so my question is would you continue to drive your car? or would you get it fixed before you drove the car any longer? also lets say the axel was to completly give out what exactly would happen?
Old Jan 23, 2005 | 05:13 PM
srfnscubamunkey's Avatar
Default Re: axel problem (PleaseHelp)
to things could happen
if its breaks inside of the joint: a real nasty sound, you'll probaly be able to make it home.
outside the joint it can slap all around the fron suspension and mess lots of things up, happins rarely
Old Jan 23, 2005 | 06:19 PM
ricepicker's Avatar
If it breaks in side the cup on the passenger side, you won't be able to make it home, unless you have a LSD. Best advice on Axles: Get new ones, and replace both at the same time. If one breaks, most places offer Lifetime warranty on axles. So just go down and swap em out.
Old Jan 24, 2005 | 03:38 PM
Calean007's Avatar
Default Re: axel problem (ricepicker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ricepicker &raquo;</TD></TR><TR><TD CLASS="quote">If it breaks in side the cup on the passenger side, you won't be able to make it home, unless you have a LSD. Best advice on Axles: Get new ones, and replace both at the same time. If one breaks, most places offer Lifetime warranty on axles. So just go down and swap em out.</TD></TR></TABLE>
Does that lifetime warranty apply to remans?
Old Jan 24, 2005 | 04:18 PM
PleaseHelp's Avatar
as of now the only time i can tell there is a problem with my axel is when i turn...you can defanitly hear a sound? im worried if i should continue to drive on it or not
Old Jan 24, 2005 | 04:19 PM
you can drive on them but drive easy and ONLY when you have to replace them ASAP
B18 CYA
Jun 8, 2006 10:00 AM
JFG Kevin
Mar 16, 2006 01:38 PM
JDM_Ej
Dec 22, 2005 03:16 AM
JDM_Ej
Suspension & Brakes
Dec 13, 2005 03:52 PM
sparxx
Mar 19, 2005 04:09 AM
