Changing Brake Pads and Rotors
I think this is a simple questions, For a 1989 Accord Lxi i need to change the brake pads and the rotor. what do i need to change the back ? thanks.
Re: Changing Brake Pads and Rotors (rombios)
you need to change brake shoes and if needed machine the drums ,also pull the boot from the wheel cylinders a bit ,make sure there is no brake fluid coming out if u see brake fluid u need to replace wheel cylinders
sunnyside
09-05-2005 06:46 AM
