A/C Problem again
Old Aug 10, 2006 | 07:08 AM
Ruskimafia's Avatar
Default A/C Problem again
as some off u know i had my a/c compressor on a 00 v6 replaced about 2 months ago b4 i left the country. well i got a call from my mom and was told the car is back in the shop b/c the a/c stopped working well wen i had it replaced they said theres a short some where but it still worked. So a few days ago they replaced a fuse hoping that would fix it . they also said the short is some where in the fuse box under the hood. i have a local junk yard that has a wrecked 00 2Dr v6 can i interchange fuseboxes?? is the 2dr fuse box the same as the 4 DR ?
any suggstions why this could be happening
looking for option and opinions
Thanks
Old Aug 10, 2006 | 04:30 PM
Cantstop's Avatar
Default Re: A/C Problem again (Ruskimafia)
check for corrosion in the fuse box (green/blue build up ) swollen wires , if the fuse is blown then it is a short if fuse is ok it is what is referred to as an "open " circuit
crud, broke wires cause this ,bad connection in the wiring harness (a/c) circuit could be the culprit too
Old Aug 11, 2006 | 12:00 AM
Ruskimafia's Avatar
Default Re: A/C Problem again (Cantstop)
when u say bad connection in the wiring harness (a/c) circuit could be the culprit too
could this be the a/c control unit inside the car. i mean the where u can conrtol the temp and turning a/c on and off ?
Old Aug 11, 2006 | 01:15 AM
Jmumblez2001's Avatar
i were you i'd search the archives, you'll get more info in there. i doubt ppl will
wanna repost on the same subject.
Old Aug 11, 2006 | 07:12 AM
Ruskimafia's Avatar
ok sorry for that but i had posted this problem up b4 summer ever started the main question was are 2dr and 4dr fuses boxes diff or the same ????
Old Aug 13, 2006 | 12:26 AM
Default Re: (Ruskimafia)
they are the same
Old Aug 13, 2006 | 07:03 AM
Duane_in_Japan's Avatar
Default Re: (Jmumblez2001)
Any AC problem is going to require pressure readings, system operational and just prior to system kicking off.
Old Aug 13, 2006 | 10:11 PM
Ruskimafia's Avatar
Default Re: (Duane_in_Japan)
Pressure reading are at proper psi
Old Aug 17, 2006 | 05:12 PM
Cantstop's Avatar
i was referring to the engine compartment area as this is where wiring gets the most abuse from heat and oil, as well as from the elements of weather
a good honda dealer will usually diagnose your car for 1 hour worth of labor as the charge and will typically give you credit for that 1 hour if you decide to let them fix the car.
Old Aug 18, 2006 | 06:00 AM
Default Re: (Cantstop)
I dont know about the fuse box issue swap over but I THINK I am pretty good with AC, it may be electrical and maybe I cannot point you in the right direction like this but if you can give pressures both when the system shuts off and a few seconds after it comes back on I CAN let you know where to go from there PLEASE, are you trying to help your mom, are you not at home now.
Trying to help.
XRacerX
Sep 9, 2009 08:50 AM
Sic_DA_Nine
Jan 8, 2007 09:54 AM
V-Thang
Acura TL, RL & ZDX
May 28, 2005 11:33 AM
rizen
Dec 21, 2003 09:48 AM
playerzz
Nov 11, 2003 12:22 AM
