1996 HONDA ACCORD EX OVERHEATING
Old 08-16-2006, 11:22 AM
PREACHERBREW's Avatar
Default 1996 HONDA ACCORD EX OVERHEATING
Can someone help me please, my 1996 accord has been overheating, I don't see a leak anywhere, the overflow tank top keeps popping off and the water evaporates, then the temp needle gradually shoots up to the red, I have to continue to put water in the radiator and overflow tank, what am I doing wrong? I've already replaced the thermostat, any suggestions?
Old 08-16-2006, 11:54 AM
BlUAc's Avatar
Default Re: 1996 HONDA ACCORD EX OVERHEATING (PREACHERBREW)
well is your fan working? and I believe it can mean a sign of a blown head gasket
Old 08-16-2006, 12:00 PM
Default Re: 1996 HONDA ACCORD EX OVERHEATING (BlUAc)
The fan on the passenger side comes on when I turn the car off, I don't think the fan on the drivers side is working, when is that one supposed to come on?
Old 08-17-2006, 02:21 AM
BlUAc's Avatar
ya the driver one comes on when the ac is on how long has it been since a coolant change does it need it
Old 08-17-2006, 02:24 AM
BlUAc's Avatar
also on a cold start open the radadiator cap when on to see if you see any water movement from the water pump if you have a smooth idle you will see a little slushing around in there
Old 08-19-2006, 11:48 AM
sony224422's Avatar
replace your rad. i just did it for the same reasons, and the drivers side fan won't come on unless the raditor is full. I found that out too.
Old 08-19-2006, 01:18 PM
stephenastacio's Avatar
first of all buddy get rid of the water. it will eat your head. second change your thermostat. if that doesnt work thenit may be your water pump.
cgeorge
08-03-2015 08:44 AM
Spithead051
07-12-2013 03:18 AM
Skoalbandit
06-16-2012 02:34 PM
lazychina
10
06-30-2011 07:16 PM
PREACHERBREW
08-17-2006 05:35 PM
Quick Reply: 1996 HONDA ACCORD EX OVERHEATING
