driver window
Old Jun 1, 2007 | 07:29 PM
eg6civic1538's Avatar
Default driver window
i need help getting the door panel off the driver side door. its got power locks and power windows. any helpful advice on how to take it off without braking anything..?
Default Re: driver window (eg6civic1538)
its a 94 2 door
Old Jun 1, 2007 | 10:19 PM
H22CD7's Avatar
just be careful with the snap clips once all the screws are out of the door, they are pretty easy to break. Pull them straight out and it helps if you have something to help pry them out too. After all the snap clips are undone the only thing holding the panel on should be the top part along the window. Pull the panel out some and unclip the power lock and window plugs behind the panel then pull the panel straight up. I usually end up having to smack the bottom of the panel a couple times to help get it started. Just make sure your pulling the panel up and not out.
Its pretty easy to do, good luck.
aznomb
Honda Civic (2001 - 2005)
Jul 9, 2010 03:46 AM
casper.hughes
Oct 12, 2008 06:33 PM
fasterthanrayswrx
Jan 26, 2007 04:36 PM
DOHC_VTEC69
Feb 3, 2005 11:39 AM
NavyHonda95
Oct 11, 2004 07:04 AM
