Help Please
Old May 25, 2007 | 04:41 PM
Salisha88's Avatar
Default Help Please
My boyfriend has a 92 accord lx 5 speed it had a body kit on it but someone messed up the front bumper so we had to take that one off but we have the stock front bumper but we do not know what parts that we need to put it back on. Also when you drive the car and you stop at a stoplight the cars rpm's will jump from 700rpm's to 1500rpm's. I would really appriciate the help if anyone can help thank you
Old May 25, 2007 | 04:42 PM
accord380whp's Avatar
Default Re: Help Please (Salisha88)
as far as your idle goes , I would check the IACV .
Old May 27, 2007 | 03:39 PM
hondadude's Avatar
Be sure the coolant is full and the block burped thru the 12mm bleed screw at the T-stat housing; if that is all okay open the top of the FITV [2 phillips screws] and turn the nylon "split screw" down a couple turns onto the brass cone.
unbreakable_35
Feb 5, 2009 05:44 PM
EG694Si
Mar 10, 2008 08:14 PM
tpfu85
Dec 5, 2007 09:38 PM
accordmaniac23
Feb 10, 2007 10:35 AM
civicboy95
Feb 24, 2002 04:44 PM
