91 accord auto to manual conversion??
Well a friend and i are doing a manual conversion on his accord, and were almost done, we already installed the trans and cables, moved the mount forward, put the pedals in, cltuch line, ecu..
Is there any thing that we might have missed,
i tried to turn the car over but the car didnt turn???
Help please!!
Help please!!
Re: 91 accord auto to manual conversion??
check all your grounds. i tore apart my D series put it all back and it wouldnt crank turned out to be a bad ground. if that doesnt solve anything check for power at the starter have a buddy turn the key. im assuming it would be 12 volts running into it so wire up a test light. also make sure u wired up the clutch sensor so the ecu knows when u have the clutch down its a little button on the top of the pedal
now why would he do that? hes already got it done the tranny is installed and ready to run just got to get the car running. your just gonna end up making him spend more. and its not hes car he said it was his buddies. oh and some people like taking on projects
There is two switches on the clutch pedal, one above the other. One is for the starter interlock (depress clutch to start) the other one is to disengage the cruse control. I think the cruse control is on top and the interlock for the starter is on bottom.
vonjay12
11-10-2017 02:41 PM
CD8coupeSiR
07-15-2006 01:06 PM
D_TY3
09-30-2003 09:27 AM
