which block will work
Old Jun 10, 2007 | 10:48 PM
rico892002's Avatar
Default which block will work
guys i have a 95 accord ex. i recently spun a bearing in my bottom end and 2marrow i was going to go to a local junk yard to pick up a new block. I wanted to know can i put my sohc vtec head on any f22 blocks even if there a older year an a non vtec block. will it work? if i get a non vtec block, what will i have to do to make my sohc vtec head work with the non-vtec block.
Old Jun 11, 2007 | 12:30 AM
cb7tougeracer's Avatar
Default Re: which block will work (rico892002)
same as a ls/vtec take the block for oil line check and a parts store and see if the head caskets are the same also
Old Jun 11, 2007 | 07:37 AM
rico892002's Avatar
Default Re: which block will work (cb7tougeracer)
thats it
Old Jun 11, 2007 | 07:48 AM
TouringAccord's Avatar
H-T Order of Merit
yes, you can take an older F22 non-vtec block or probably even a newer F22/F23 block and make it work.
Go to the FAQ and look in the swap section. There are some links to SOHC VTEC head swaps, thats what you'll want to look at to see whats involved.
Old Jun 11, 2007 | 10:12 AM
rico892002's Avatar
Default Re: which block will work (TouringAccord)
o ok
Tomina
Dec 23, 2014 05:28 AM
SoFresh1189
Jul 15, 2010 11:07 AM
freakasis
Jan 31, 2010 06:36 PM
blueaccord90
Feb 10, 2005 08:13 PM
