Overheating!!!
Old Jun 4, 2007 | 11:20 AM
opg5009's Avatar
Default Overheating!!!
seems like i have bad luck with my car, i have a 1993 honda accord EX,4 door, and when the engine warms up while i am driving it is fine but when i stop and it is idle the tempature rises almost to the point to where it might overheat but when i accelerate the tempature falls back down. I really don't know what is going on.
Old Jun 4, 2007 | 11:41 AM
hondadude's Avatar
Default Re: Overheating!!! (opg5009)
First thing you could do is check for cooling fan operation; when the car is moving there is air flow thru the radiator, but when you are stopped and the cooling fans Do Not run there is no air flow thru the radiator.
Old Jun 11, 2007 | 02:39 AM
pos_cd5's Avatar
what you are describing sounds like exactly what happens when your fan isnt working. i would check that first. if the fan is operational then check all the other stuff stated above:
coolant level
air in the system
leaks
thermostat
waterpump
and if everything checks out try giving your cooling system a good flush and refill. if that doesnt help either then most likely your raidator needs replacing or there is something blocking airflow to your radiator.
Old Jun 11, 2007 | 07:16 AM
TheMuffinMan's Avatar
He knows where you live!
Kinda a thread jack, what's the test for the fan again? I recall it being removal of a sensor?
Mine's overheating while idling
Old Jun 11, 2007 | 07:33 AM
cb7tougeracer's Avatar
Default Re: (TheMuffinMan)
yea check fans and thermostat i got a spare thermostat if you need one
Old Jun 11, 2007 | 07:41 AM
YeuEmMaiMai's Avatar
put the fan directly to battery voltage to test it. Most likely is a toasted relay. when you turn your AC does the other fan come on?
Old Jun 11, 2007 | 08:12 AM
mzmarsaw's Avatar
Default Re: Overheating!!! (blue01EX)
Hi. Look my car is doing something similar. I drive around town and I am fine, but when I go out of town and do long stretches on the highway, the temp gauge goes up after I have been driving a while. Then once I stop at a light or something, it goes all the way up, then once I accelerate, it drops back down for a while. What the F?
Old Jun 11, 2007 | 08:15 AM
Yeah Yeu, to my knowledge it does, I'll have to play with it more later, I think sometimes it comes on and sometimes it doesnt.
Is the relay on the fan itself or further up the wire?
Old Jun 11, 2007 | 08:40 AM
I believe the relays are either
at the cross memeber or fender area. I am not sure
take a look here (off of a 5th gen car)
Gelignite
Jul 13, 2015 04:22 PM
gabriel0830
15
Jul 10, 2013 06:55 AM
JigsN Joints
Aug 18, 2011 12:32 AM
sherms48
Apr 9, 2007 01:35 AM
KB96VTEC
May 23, 2005 06:30 PM
