help timing problem
Old Mar 16, 2008 | 01:05 PM
f22kid's Avatar
Default help timing problem
okay i just did a timing belt and a balance shaft belt on my 92 f22a1 because i was getting a no start condition. i put everything back together still no start so i pulled the plugs and cyl 2 and 3 were fried. so i replaced them and no it starts but runs like crap. i wasnt sure of the timing marks on the balance shaft belts system so i guessed it and im almost sure it was right and then now this.... if anyone can help that would be so helpful seeing in how i have a kid on the way very soon and i need this car A.S.A.P. thank you
Old Mar 16, 2008 | 01:08 PM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: help timing problem (f22kid)
As long as the timing belt was installed correctly, the balance shaft belt doesn't matter. Pull the covers, remove the belt, reset to TDC and try again.
Old Mar 16, 2008 | 01:16 PM
f22kid's Avatar
Default Re: help timing problem (213374U)
well i was thinking maybe i croseed some of the wires because for some reason im so dumb i still cant under stand it even though ive checked it many times maybe theyre crossed or maybe there could be something else
Old Mar 16, 2008 | 01:37 PM
213374U's Avatar
0x5359-0055
Community Builder
If you think you may have "crossed some wires" (assuming your talking about plug wires) and you just finished doing the timing belt yourself..... your next move is to call someone with some mechanical know-how to personally check your work.
Old Mar 16, 2008 | 02:19 PM
f22kid's Avatar
i guess what i meant to say was that im really unsure of myself when it comes to my car lol for some reason the wires are right but the car runs like there are two wires crossed could that be becasue of a timing issue
Old Mar 16, 2008 | 02:29 PM
213374U's Avatar
0x5359-0055
Community Builder
It could be a number of things but unless you're positive that you performed the work correctly, there's really nothing that anyone on this board can do for you. You need to have someone that can put there hands on the car look at it for you. Sorry we can't help.
Old Mar 17, 2008 | 11:32 AM
f22kid's Avatar
well heres the problem i stayed up till 5 a.m. this morning figuring out what it was. standing out in 15 degree weather didnt help any but i figured out what the problem was. it turns out the timing marks on my cam gear are misprinted everything was lined up to the T and the timing was still off by two teeth it took three times to go one tooth at a time and it purrs like a kitten.
Old Mar 17, 2008 | 06:06 PM
213374U's Avatar
0x5359-0055
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by f22kid &raquo;</TD></TR><TR><TD CLASS="quote">it purrs like a kitten.</TD></TR></TABLE>
Good to hear you figured it out
tobytigger
Jun 27, 2017 10:54 AM
sickofitall1113
Nov 23, 2006 09:39 PM
maxion$mulla$
Nov 7, 2006 06:57 PM
aaaabbbb
Oct 5, 2004 03:02 PM
Finest
Oct 8, 2002 07:01 AM
