94 Accord Engine Vibration/Rough Idle
Old 07-04-2009, 06:44 PM
billy barker's Avatar
Default 94 Accord Engine Vibration/Rough Idle
My 94 Accord LX 4cyl with A/T (140,000 miles) idles a little rough at normal idle with the A/C off. When the A/C is on the engine really vibrates noticeably when the car is in drive with foot on the brake - putting it in neutral will smooth it out a bit). Otherwise, it seems to run fine with good pick up etc. I'm inclined to think it is a bad motor mount, but not sure which one it might be. Does anyone have any suggestions as to the cause of this vibration or the best way to troubleshoot? Thanks in advance for your help!
Old 07-11-2009, 04:27 PM
gold95accord's Avatar
Default Re: 94 Accord Engine Vibration/Rough Idle
Good question... I recently did my AC and im noticing that my idle is kind of rough too... I know its not my motor mounts but any ideas would greatly help...
Old 07-11-2009, 05:06 PM
be professional
Targa250R's Avatar
It's not "normal" per se, but it is very common - probably about 70% of the '90-97 automatic Accords that I've driven will do this. I believe it's caused by a bad rear engine mount - the $290 electronic/vacuum-controlled one.
epichonda91
07-18-2013 11:06 AM
masti
12-11-2009 07:58 PM
steelerfan7111
10-16-2008 02:30 PM
ajth87
03-13-2006 02:41 PM
fever502
01-09-2006 05:49 PM
Quick Reply: 94 Accord Engine Vibration/Rough Idle
