srs module location
Old 06-25-2009, 06:55 PM
New User
tr71270's Avatar
Default srs module location
i have a 2000 accord coupe, it was involved in a accident and im replacing the airbags and module but cant seem to find where the srs module is located, anyone know where?
Old 06-25-2009, 07:09 PM
FunnyVictor86's Avatar
Default Re: srs module location
i believe it's underneath the center console towards the dash ... next to the ecu
GhostAccord's Avatar
I'm pretty sure it's directly behind the center console, mounted to the top of the exhaust tunnel, close to the fire wall.
Sorry for the mess but I think you can see it's relation to the gas, brake & clutch peddles and the shifter.
This is for a 5th gen, but I'm pretty sure the 6th gen is in relatively the same position.
here is a parts image for the 6th gen SRS unit.
http://www.hondapartsdeals.com/hpa/z...e&x=1107&y=553
Old 06-25-2009, 07:17 PM
yes the same on 6th gen
Old 06-25-2009, 07:30 PM
New User
tr71270's Avatar
thanks i will check in the morning, the images will really help.
Thanks again
Old 06-26-2009, 02:05 AM
onlyvtec's Avatar
FYI All Honda cars use yellow electrical tape to tell the difference between other wiring harnesses and the SRS harnesses . DO NOT cut these wires. They are usually the same color and are a bitch to figure out how to reattach. Had a customer do that once.
Old 12-11-2013, 11:14 AM
auggiegarcia's Avatar
Do you have any instructions on how to remove and replace the center console for 2009 CR-V, thanks
A.G.
Boarderx192
02-20-2006 09:45 AM
esca
03-04-2005 10:26 PM
hatchback
Audio / Security / Video
05-12-2003 01:49 PM
Razor
03-05-2002 05:18 AM
D
03-02-2002 01:59 PM
Quick Reply: srs module location
