Clock light doesn't work
Old Oct 9, 2002 | 12:02 PM
B2FiNiTY's Avatar
Default Clock light doesn't work
The clock no longer lights up at night. Simple fuse fix?
Old Oct 9, 2002 | 12:56 PM
Nick M's Avatar
Default Re: Clock light doesn't work (ExOdy)
most likely
Is this the only forum you havent PW'd in?
Old Oct 9, 2002 | 01:35 PM
Chiovnidca's Avatar
Most likely the bulb, see them all the time.
Old Oct 9, 2002 | 02:00 PM
Nick M's Avatar
Default Re: Clock light doesn't work (Chiovnidca)
I was assuming he already checked the bulb. That would be the obvious first step
Old Oct 9, 2002 | 02:14 PM
Chiovnidca's Avatar
Default Re: Clock light doesn't work (Nick M)
If it was the fuse he would have alot of other problems with circuits on the same fuse.
Old Oct 9, 2002 | 04:56 PM
B2FiNiTY's Avatar
Low blow Nick. I guess I'm notorious around here.
Well, it's my g/f's car and I didn't have time to check anything last weekend. Is the clock hard to take out? I'll just get a flathead and work on it.
Old Oct 9, 2002 | 10:35 PM
Gen4-5Door's Avatar
It's the light behind the clock. Very common. The whole dash bezel around the instrument cluster and clock comes out as one piece. The bulb is only a few bucks. Don't try to pry the clock out of the dash, it's bolted in from behind. Good luck.
Old Oct 10, 2002 | 12:39 AM
B2FiNiTY's Avatar
Default Re: Clock light doesn't work (Gen4-5Door)
Where exactly do I start to take off stuff? I don't want to take off more than needed.
Old Oct 10, 2002 | 12:40 AM
B2FiNiTY's Avatar
If you got pics, that would help too.
2000 Accord Coupe V6.
Old Oct 10, 2002 | 04:31 AM
90H22's Avatar
Just curious about your 14,000 posts. Is that for real or did you just hack the code or something?
Oh, and you might want to put a thin piece of tape on the end of the skinniest flathead you can find. Keeps it from scratching anything.
Old Oct 10, 2002 | 07:10 AM
Nick M's Avatar
Default Re: Clock light doesn't work (90H22)
It was done as a joke because he about 900 posts in the last 7 days.
Old Oct 10, 2002 | 02:48 PM
B2FiNiTY's Avatar
So where should I start tearing the dash apart?
Old Oct 10, 2002 | 02:51 PM
Chiovnidca's Avatar
What year and model?
Old Oct 10, 2002 | 03:00 PM
90H22's Avatar
The clock pops right out, you can just use that screwdriver to pop it out and you'll be able to remove the bulb.
Old Oct 10, 2002 | 04:45 PM
B2FiNiTY's Avatar
B2FiNiTY's Avatar
Thanks, I'll fix it this weekend.
Old Oct 10, 2002 | 05:40 PM
fast93accord's Avatar
i replace clocklights all the time, in cars new and old. Some cars take a minute, other cars take longer. The clocklight looks like a LED.
Old Oct 10, 2002 | 08:40 PM
B2FiNiTY's Avatar
Default Re: Clock light doesn't work (fast93accord)
Does anyone know the bulb #?
peter.s
Apr 9, 2018 05:27 PM
Cpolinsky
Aug 14, 2013 01:30 PM
ZombiePharoh
Feb 26, 2012 07:21 PM
pLaTiNuM_pLuS_cRx
Oct 21, 2004 05:50 AM
GSlowR
12
Oct 5, 2002 07:14 PM
