Window problem - 94 EX
Old Dec 23, 2002 | 12:37 PM
munscher's Avatar
Default Window problem - 94 EX
Hey guys, having a problem with the drivers side window on a 94 EX coupe. The window won't move up or down with the switch but the motor seems to be trying so i dont' think its electrical. My guess from looking at it is that the cable came loose from the regulator? The metal cable still moves back and forth with the switch but the other end isn't attached to anything. Can't seem to find where it should attach... any help? pictures? diagrams? TIA
Old Dec 23, 2002 | 01:13 PM
RotaryBzzz's Avatar
Default Re: Window problem - 94 EX (munscher)
wire part of the window regulator is snapped. Unfortunately, those things cannot be fixed.
Replace the whole PW door regulator mechanism: ~70-95 bucks new. $10-15 bucks + time from a junkyard (although who-knows how long it will last - good if yer getting rid of the car soon)
[Modified by RotaryBzzz, 2:13 PM 12/23/2002]
Old Dec 23, 2002 | 02:57 PM
Ideal's Avatar
Default Re: Window problem - 94 EX (RotaryBzzz)
maybe the resonator?
Old Dec 23, 2002 | 04:53 PM
Chiovnidca's Avatar
Default Re: Window problem - 94 EX (Ideal)
Huh???
Old Dec 23, 2002 | 04:56 PM
munscher's Avatar
Default Re: Window problem - 94 EX (Chiovnidca)
Haha, i'm with you on this one... maybe the resonator???
But anyhow, i don't think the cable snapped, on both ends it has a piece that is cylindrical and bigger than the rest of the cable that would keep the cable from pulling through a hole through which the cable WOULD slide. Wish i had pictures. I think one of the ends of the cable slipped out of where it should be.
Old Dec 24, 2002 | 12:21 PM
munscher's Avatar
nobody got any ideas? or links maybe?
Old Dec 24, 2002 | 01:12 PM
Razor's Avatar
happened to my passenger side window, one day i pushed the down button and the whole window fell down. the cable snapped so i just installed a new window regulator from my job and installed it in less than 15 minutes the first time.
Old Dec 24, 2002 | 01:30 PM
Chiovnidca's Avatar
Probably needs a new regulator.
Old Dec 24, 2002 | 01:37 PM
munscher's Avatar
do any of you guys understand at all what i'm saying about the cable? cuz in no way does it look like it snapped or broke.... the motor still turns with the switch and the cable moves but it looks like the cable's off track or fell outta place.... maybe something else is wrong, but the cable isn't snapped in two
Old Dec 24, 2002 | 01:40 PM
Razor's Avatar
if the cable isn't snapped than i guess you can take it apart and repair it...i'm not a window specialist though
Old Dec 24, 2002 | 01:42 PM
Chiovnidca's Avatar
Ive never seen a fucked up cable regulator that could be repaired. It's probably not going to hurt to try though. Let us know what happens.
Old Dec 24, 2002 | 04:31 PM
munscher's Avatar
im not sure how you guys have replaced it, i can't even see what's all in there very clearly, its all hidden behind the metal of the door... itd be hell to replace it i think.... the box itself seems easy enough (4 bolts) but i dont know what to do with the cable. anybody have schematic of the door?
Old Dec 24, 2002 | 10:34 PM
RotaryBzzz's Avatar
I've tried fixing these door regulators. NOT WORTH THE TIME. It didn't work anyway....those wire sons-a-bitches are perfectly wound within the mechanism. Once there out, there is no way in hell to wind them perfectly again. Too...........much........................aggravat ion..............................save.......yourse lf........................
Old Dec 24, 2002 | 11:18 PM
Ideal's Avatar
how do you replace a regulator in a 93 accord, i dont get how i can fit my hands in there...
Old Dec 25, 2002 | 01:32 PM
RotaryBzzz's Avatar
It's fully described in any manual...helms or haynes...for any car. Just look under "door regulator removal" and infer
Old Dec 25, 2002 | 07:34 PM
munscher's Avatar
so anyone got that that they can post? just those pages? iv'e got one for my prelude, but not my brothers 94 accord
Old Dec 25, 2002 | 10:27 PM
RotaryBzzz's Avatar
it's basically the same....
Old Dec 27, 2002 | 09:52 AM
munscher's Avatar
got the bolts out, now what?
Old Dec 27, 2002 | 10:15 AM
TJCCARDCO's Avatar
On my other car (94 Accord EX in Black) it (the window) goes up real fast, up and down in the rain. But other than when its raining, the ************ takes forever to get up to the top, I have to push it to the side and then it starts going up but only when i push the windows. Weird, eh?
Old Dec 27, 2002 | 10:56 AM
munscher's Avatar
Default Re: Window problem - 94 EX (TJCCARDCO)
oops, i'm an idiot and missed the two bolts holding the window to the slide, the job is done now and it works perfect, thanks for the help fellas
Old Dec 27, 2002 | 01:15 PM
Chiovnidca's Avatar
Were you able to repair your old regulator or did you install a new one?
Old Dec 27, 2002 | 02:59 PM
ai motorsports's Avatar
if it doesn't move, that mean the motor is jamm. take a hammer and hit it and if that dont work change the motor.
Old Dec 27, 2002 | 04:13 PM
munscher's Avatar
I installed a new one.... i'm gonna rip into the old one to see if i can fix it.... the cable has come loose from where the ends come together on the slide but i can't just put 'em back cuz there's some of the cable tangled inside the regulator itself it seems, so i'm gonna take that apart.
Old Jan 12, 2003 | 09:45 PM
MLB's Avatar
MLB
Looks straight forward in the manual. It does say to mark around the bolt heads that are the adjustable slots so that you put them back where they were - adjustment wise.
How much was the part? OEM or aftermarket?
Old Jan 13, 2003 | 07:49 AM
gatoracer's Avatar
Default Re: Window problem - 94 EX (MLB)
My power windows also go and down kinda slow. It gets worse in the summer. Is there a difference between the regulator and the motor? Should I replace both?
94 accord ex
