Steering problem
Old Dec 15, 2002 | 04:57 AM
DaveAcc98's Avatar
Default Steering problem
Had some repair work done and now...
Steering doesnt feel right... there isnt as much resistance on the wheel as there used to be, and it doesnt feel as responsive in the begginings of a turn.
I dont know very much about cars.. but I really like my car.. and want it to feel perfect.
btw.. i drive a 98 accord coupe 4cyl lx
Old Dec 15, 2002 | 06:24 AM
jweller's Avatar
Default Re: Steering problem (DaveAcc98)
Well number one, what work did you have done? and why?
go check the fluid level.
Old Dec 16, 2002 | 07:35 AM
DaveAcc98's Avatar
I already checked the fluid level... Its at the top indicator...
I slid into a curb... one wheel collided with it.
The rim had to be replaced .. and two other things... i think they were the air intake... and a steering rod? iam not sure about the last one.. and also i got an alignment.
Old Dec 16, 2002 | 08:40 AM
TouringAccord's Avatar
H-T Order of Merit
I'm interested also, due to the fact that I just curbed my car a couple weeks ago and haven't really gotten to much done yet.
Is this all that you replaced? How hard did you hit?
Old Dec 16, 2002 | 08:45 AM
urbanlegend21's Avatar
New User
Default Re: Steering problem (TouringAccord)
car is probably out of alignment, toe is screwed up or something
Old Dec 16, 2002 | 09:18 AM
DaveAcc98's Avatar
its not out of alignment... it was just realigned... i hit at probably 15mph? it was straight off from a red light.. it was raining and the road had leaves in it...
After i hit, the steering wheel had to be turned to the right to make the car go straight... thats all better now... but the feel isnt right now..
so.. any ideas?
Old Dec 17, 2002 | 03:26 AM
DaveAcc98's Avatar
no one? i figure if you guys dont know, its hopeless...
Old Dec 17, 2002 | 03:41 AM
New User
just cause they aligned it doesn't mean they fixed toe or camber issues
did you get a print out of the alignment? if you did give the measurements
Old Dec 17, 2002 | 09:03 AM
DaveAcc98's Avatar
Default Re: Steering problem (urbanlegend21)
Ok, if i have it.. its at home.. so ill get it and post this weekend. If thats the problem.. is it expensive to adjust? is it hard to do it myself?
[Modified by DaveAcc98, 6:03 PM 12/17/2002]
Old Dec 17, 2002 | 09:07 AM
RotaryBzzz's Avatar
With a curb hit like that, you sound like you might've screwed up the control arm. The whole arm might be bent out of alignment at some angle.
Old Dec 17, 2002 | 09:58 AM
DaveAcc98's Avatar
Default Re: Steering problem (RotaryBzzz)
the control arm! that was replaced.
I couldnt remember the name of it before... but iam pretty sure thats it.
remember.. the problem isnt that the car doesnt go straight..
it goes straight.... the steering wheel just feel loosish...
[Modified by DaveAcc98, 6:59 PM 12/17/2002]
Old Dec 17, 2002 | 10:05 AM
RotaryBzzz's Avatar
sounds like air bubbles in your power-steering system. Bleed the system by starting up the car and, without moving, turn the steering wheel all the way to the right then all the way to the left a couple times.
Old Dec 17, 2002 | 12:50 PM
jweller's Avatar
that will bleed the P/S system? I've just learned something
Old Dec 17, 2002 | 01:36 PM
smokin rubber's Avatar
Default Re: Steering problem (jweller)
yea it really it that easy.
Old Dec 18, 2002 | 04:44 AM
DaveAcc98's Avatar
Default Re: Steering problem (smokin rubber)
like in park?
Old Dec 18, 2002 | 12:23 PM
RotaryBzzz's Avatar
like in park?
Sure, why not?
Also, it would be good for the life of your tires if you did it in a water puddle or something. Don't "force-it" at the end of lock" either...not good for the pump (you'll hear it whinning)...
mreed
Oct 20, 2010 10:54 AM
dc5alldayy
Oct 30, 2008 10:21 PM
m0nee
Apr 12, 2008 02:21 AM
avallach
Oct 31, 2006 12:48 PM
robpreludevtec220
Feb 28, 2006 01:57 PM
