high compression ???
Old Dec 16, 2002 | 08:50 PM
94accordh22a's Avatar
Default high compression ???
my h22a motor is pushing out 225 on the compression with a dry run ? is that bad or good ? i did the run a few times and ever time the same .
94 accord h22a motor swap :
-areospeed intake
-dc sports header
-lightweight findenza flywheel
-ACT clutch 6 puck
-apex n-1 exhaust ( left the same clogged cat )
-ultra ss complete pulleys set
-hondata ecu chip
i just bought msd ign. msd blaster . msd 8.5 wires .. walbro fuel pump .. aem fuel rail , fuel injectors , fuel press regulator .. ported and polished the head ..
Old Dec 17, 2002 | 12:33 PM
niedejb's Avatar
Default Re: high compression ??? (94accordh22a)
Its good, but you said you had a blown #1 in another post
Old Dec 17, 2002 | 12:50 PM
GZERO's Avatar
did you check compression with the gas floored?
Old Dec 17, 2002 | 12:52 PM
niedejb's Avatar
Default Re: high compression ??? (GZERO)
He wouldnt have gotten that high at part throttle.
Old Dec 17, 2002 | 12:53 PM
carolinaACCORD's Avatar
thats about the right # it should be.
what's cyl. #1, that you said was gone?
Old Dec 17, 2002 | 12:59 PM
niedejb's Avatar
Default Re: high compression ??? (carolinaACCORD)
i had it for 3 weeks and cyclinder one blew
https://honda-tech.com/zerothread?id=361623
Old Dec 17, 2002 | 01:58 PM
Default Re: high compression ??? (niedejb)
cyclinder one was pushing around 40 ... but before it went it was the same as the others
Old Dec 17, 2002 | 02:05 PM
Razor's Avatar
whats a good compression number for a stock 94-95 obd1 f22b1? like 160?
Old Dec 17, 2002 | 02:12 PM
niedejb's Avatar
Default Re: high compression ??? (Razor)
178 psi
135 minimum
All should be within 28psi of each other
Above "accord"ing to my service manual....
Ruben19
Mar 10, 2006 03:23 AM
CrazieLude
Dec 20, 2002 03:26 AM
Guru
Dec 19, 2002 02:41 AM
94accordh22a
Dec 16, 2002 04:45 PM
