OBD II : Complete Codes for your OBD II Reader - linked
FYI
http://au.geocities.com/ozbrick850/obd2codes.html#obd-2
Just in case the link dies one day:
These are the OBD-II codes that are common to all the cars that are OBD-II compliant.
P0100
Mass or Volume Air Flow Circuit Malfunction
P0101
Mass or Volume Air Flow Circuit Range/Performance Problem
P0102
Mass or Volume Air Flow Circuit Low Input
P0103
Mass or Volume Air Flow Circuit High Input
P0104
Mass or Volume Air Flow Circuit Intermittent
P0105
Manifold Absolute Pressure/Barometric Pressure Circuit Malfunction
P0106
Manifold Absolute Pressure/Barometric Pressure Circuit Range/Performance Problem
P0107
Manifold Absolute Pressure/Barometric Pressure Circuit Low Input
P0108
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0109
Manifold Absolute Pressure/Barometric Pressure Circuit Intermittent
P0110
Intake Air Temperature Circuit Malfunction
P0111
Intake Air Temperature Circuit Range/Performance Problem
P0112
Intake Air Temperature Circuit Low Input
P0113
Intake Air Temperature Circuit High Input
P0114
Intake Air Temperature Circuit Intermittent
P0115
Engine Coolant Temperature Circuit Malfunction
P0116
Engine Coolant Temperature Circuit Range/Performance Problem
P0117
Engine Coolant Temperature Circuit Low Input
P0118
Engine Coolant Temperature Circuit High Input
P0119
Engine Coolant Temperature Circuit Intermittent
P0120
Throttle/Petal Position Sensor/Switch A Circuit Malfunction
P0121
Throttle/Petal Position Sensor/Switch A Circuit Range/Performance Problem
P0122
Throttle/Petal Position Sensor/Switch A Circuit Low Input
P0123
Throttle/Petal Position Sensor/Switch A Circuit High Input
P0124
Throttle/Petal Position Sensor/Switch A Circuit Intermittent
P0125
Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126
Insufficient Coolant Temperature for Stable Operation
P0130
O2 Sensor Circuit Malfunction (Bank 1 Sensor 1)
P0131
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 1)
P0132
O2 Sensor Circuit High Voltage (Bank 1 Sensor 1)
P0133
O2 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136
O2 Sensor Circuit Malfunction (Bank 1 Sensor 2)
P0137
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 2)
P0138
O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139
O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142
O2 Sensor Circuit Malfunction (Bank 1 Sensor 3)
P0143
O2 Sensor Circuit Low Voltage (Bank 1 Sensor 3)
P0144
O2 Sensor Circuit High Voltage (Bank 1 Sensor 3)
P0145
O2 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146
O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 3)
P0147
O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 3)
P0150
O2 Sensor Circuit Malfunction (Bank 2 Sensor 1)
P0151
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
P0152
O2 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153
O2 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156
O2 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158
O2 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159
O2 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162
O2 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163
O2 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164
O2 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165
O2 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166
O2 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167
O2 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
P0170
Fuel Trim Malfunction (Bank 1)
P0171
System too Lean (Bank 1)
P0172
System too Rich (Bank 1)
P0173
Fuel Trim Malfunction (Bank 2)
P0174
System too Lean (Bank 2)
P0175
System too Rich (Bank 2)
P0176
Fuel Composition Sensor Circuit Malfunction
P0177
Fuel Composition Sensor Circuit Range/Performance
P0178
Fuel Composition Sensor Circuit Low Input
P0179
Fuel Composition Sensor Circuit High Input
P0180
Fuel Temperature Sensor A Circuit Malfunction
P0181
Fuel Temperature Sensor A Circuit Range/Performance
P0182
Fuel Temperature Sensor A Circuit Low Input
P0183
Fuel Temperature Sensor A Circuit High Input
P0184
Fuel Temperature Sensor A Circuit Intermittent
P0185
Fuel Temperature Sensor B Circuit Malfunction
P0186
Fuel Temperature Sensor B Circuit Range/Performance
P0187
Fuel Temperature Sensor B Circuit Low Input
P0188
Fuel Temperature Sensor B Circuit High Input
P0189
Fuel Temperature Sensor B Circuit Intermittent
P0190
Fuel Rail Pressure Sensor Circuit Malfunction
P0191
Fuel Rail Pressure Sensor Circuit Range/Performance
P0192
Fuel Rail Pressure Sensor Circuit Low Input
P0193
Fuel Rail Pressure Sensor Circuit High Input
P0194
Fuel Rail Pressure Sensor Circuit Intermittent
P0195
Engine Oil Temperature Sensor Malfunction
P0196
Engine Oil Temperature Sensor Range/Performance
P0197
Engine Oil Temperature Sensor Low
P0198
Engine Oil Temperature Sensor High
P0199
Engine Oil Temperature Sensor Intermittent
P0200
Injector Circuit Malfunction
P0201
Injector Circuit Malfunction - Cylinder 1
P0202
Injector Circuit Malfunction - Cylinder 2
P0203
Injector Circuit Malfunction - Cylinder 3
P0204
Injector Circuit Malfunction - Cylinder 4
P0205
Injector Circuit Malfunction - Cylinder 5
P0206
Injector Circuit Malfunction - Cylinder 6
P0207
Injector Circuit Malfunction - Cylinder 7
P0208
Injector Circuit Malfunction - Cylinder 8
P0209
Injector Circuit Malfunction - Cylinder 9
P0210
Injector Circuit Malfunction - Cylinder 10
P0211
Injector Circuit Malfunction - Cylinder 11
P0212
Injector Circuit Malfunction - Cylinder 12
P0213
Cold Start Injector 1 Malfunction
P0214
Cold Start Injector 2 Malfunction
P0215
Engine Shutoff Solenoid Malfunction
P0216
Injection Timing Control Circuit Malfunction
P0217
Engine Overtemp Condition
P0218
Transmission Over Temperature Condition
P0219
Engine Overspeed Condition
P0220
Throttle/Petal Position Sensor/Switch B Circuit Malfunction
P0221
Throttle/Petal Position Sensor/Switch B Circuit Range/Performance Problem
P0222
Throttle/Petal Position Sensor/Switch B Circuit Low Input
P0223
Throttle/Petal Position Sensor/Switch B Circuit High Input
P0224
Throttle/Petal Position Sensor/Switch B Circuit Intermittent
P0225
Throttle/Petal Position Sensor/Switch C Circuit Malfunction
P0226
Throttle/Petal Position Sensor/Switch C Circuit Range/Performance Problem
P0227
Throttle/Petal Position Sensor/Switch C Circuit Low Input
P0228
Throttle/Petal Position Sensor/Switch C Circuit High Input
P0229
Throttle/Petal Position Sensor/Switch C Circuit Intermittent
P0230
Fuel Pump Primary Circuit Malfunction
P0231
Fuel Pump Secondary Circuit Low
P0232
Fuel Pump Secondary Circuit High
P0233
Fuel Pump Secondary Circuit Intermittent
P0234
Engine Overboost Condition
P0235
Turbocharger Boost Sensor A Circuit Malfunction
P0236
Turbocharger Boost Sensor A Circuit Range/Performance
P0237
Turbocharger Boost Sensor A Circuit Low
P0238
Turbocharger Boost Sensor A Circuit High
P0239
Turbocharger Boost Sensor B Malfunction
P0240
Turbocharger Boost Sensor B Circuit Range/Performance
P0241
Turbocharger Boost Sensor B Circuit Low
P0242
Turbocharger Boost Sensor B Circuit High
P0243
Turbocharger Wastegate Solenoid A Malfunction
P0244
Turbocharger Wastegate Solenoid A Range/Performance
P0245
Turbocharger Wastegate Solenoid A Low
P0246
Turbocharger Wastegate Solenoid A High
P0247
Turbocharger Wastegate Solenoid B Malfunction
P0248
Turbocharger Wastegate Solenoid B Range/Performance
P0249
Turbocharger Wastegate Solenoid B Low
P0250
Turbocharger Wastegate Solenoid B High
P0251
Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
P0252
Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
P0253
Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
P0254
Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
P0255
Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
P0256
Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
P0257
Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
P0258
Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
P0259
Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
P0260
Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
P0261
Cylinder 1 Injector Circuit Low
P0262
Cylinder 1 Injector Circuit High
P0263
Cylinder 1 Contribution/Balance Fault
P0264
Cylinder 2 Injector Circuit Low
P0265
Cylinder 2 Injector Circuit High
P0266
Cylinder 2 Contribution/Balance Fault
P0267
Cylinder 3 Injector Circuit Low
P0268
Cylinder 3 Injector Circuit High
P0269
Cylinder 3 Contribution/Balance Fault
P0270
Cylinder 4 Injector Circuit Low
P0271
Cylinder 4 Injector Circuit High
P0272
Cylinder 4 Contribution/Balance Fault
P0273
Cylinder 5 Injector Circuit Low
P0274
Cylinder 5 Injector Circuit High
P0275
Cylinder 5 Contribution/Balance Fault
P0276
Cylinder 6 Injector Circuit Low
P0277
Cylinder 6 Injector Circuit High
P0278
Cylinder 6 Contribution/Balance Fault
P0279
Cylinder 7 Injector Circuit Low
P0280
Cylinder 7 Injector Circuit High
P0281
Cylinder 7 Contribution/Balance Fault
P0282
Cylinder 8 Injector Circuit Low
P0283
Cylinder 8 Injector Circuit High
P0284
Cylinder 8 Contribution/Balance Fault
P0285
Cylinder 9 Injector Circuit Low
P0286
Cylinder 9 Injector Circuit High
P0287
Cylinder 9 Contribution/Balance Fault
P0288
Cylinder 10 Injector Circuit Low
P0289
Cylinder 10 Injector Circuit High
P0290
Cylinder 10 Contribution/Balance Fault
P0291
Cylinder 11 Injector Circuit Low
P0292
Cylinder 11 Injector Circuit High
P0293
Cylinder 11 Contribution/Balance Fault
P0294
Cylinder 12 Injector Circuit Low
P0295
Cylinder 12 Injector Circuit High
P0296
Cylinder 12 Contribution/Range Fault
P0300
Random/Multiple Cylinder Misfire Detected
P0301
Cylinder 1 Misfire Detected
P0302
Cylinder 2 Misfire Detected
P0303
Cylinder 3 Misfire Detected
P0304
Cylinder 4 Misfire Detected
P0305
Cylinder 5 Misfire Detected
P0306
Cylinder 6 Misfire Detected
P0307
Cylinder 7 Misfire Detected
P0308
Cylinder 8 Misfire Detected
P0309
Cylinder 9 Misfire Detected
P0311
Cylinder 11 Misfire Detected
P0312
Cylinder 12 Misfire Detected
P0320
Ignition/Distributor Engine Speed Input Circuit Malfunction
P0321
Ignition/Distributor Engine Speed Input Circuit Range/Performance
P0322
Ignition/Distributor Engine Speed Input Circuit No Signal
P0323
Ignition/Distributor Engine Speed Input Circuit Intermittent
P0325
Knock Sensor 1 Circuit Malfunction (Bank 1 or Single Sensor)
P0326
Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0327
Knock Sensor 1 Circuit Low Input (Bank 1 or Single Sensor)
P0328
Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
P0329
Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
P0330
Knock Sensor 2 Circuit Malfunction (Bank 2)
P0331
Knock Sensor 2 Circuit Range/Performance (Bank 2)
P0332
Knock Sensor 2 Circuit Low Input (Bank 2)
P0333
Knock Sensor 2 Circuit High Input (Bank 2)
P0334
Knock Sensor 2 Circuit Intermittent (Bank 2)
P0335
Crankshaft Position Sensor A Circuit Malfunction
P0336
Crankshaft Position Sensor A Circuit Range/Performance
P0337
Crankshaft Position Sensor A Circuit Low Input
P0338
Crankshaft Position Sensor A Circuit High Input
P0339
Crankshaft Position Sensor A Circuit Intermittent
P0340
Camshaft Position Sensor Circuit Malfunction
P0341
Camshaft Position Sensor Circuit Range/Performance
P0342
Camshaft Position Sensor Circuit Low Input
P0343
Camshaft Position Sensor Circuit High Input
P0344
Camshaft Position Sensor Circuit Intermittent
P0350
Ignition Coil Primary/Secondary Circuit Malfunction
P0351
Ignition Coil A Primary/Secondary Circuit Malfunction
P0352
Ignition Coil B Primary/Secondary Circuit Malfunction
P0353
Ignition Coil C Primary/Secondary Circuit Malfunction
P0354
Ignition Coil D Primary/Secondary Circuit Malfunction
P0355
Ignition Coil E Primary/Secondary Circuit Malfunction
P0356
Ignition Coil F Primary/Secondary Circuit Malfunction
P0357
Ignition Coil G Primary/Secondary Circuit Malfunction
P0358
Ignition Coil H Primary/Secondary Circuit Malfunction
P0359
Ignition Coil I Primary/Secondary Circuit Malfunction
P0360
Ignition Coil J Primary/Secondary Circuit Malfunction
P0361
Ignition Coil K Primary/Secondary Circuit Malfunction
P0362
Ignition Coil L Primary/Secondary Circuit Malfunction
P0370
Timing Reference High Resolution Signal A Malfunction
P0371
Timing Reference High Resolution Signal A Too Many Pulses
P0372
Timing Reference High Resolution Signal A Too Few Pulses
P0373
Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
P0374
Timing Reference High Resolution Signal A No Pulses
P0375
Timing Reference High Resolution Signal B Malfunction
P0376
Timing Reference High Resolution Signal B Too Many Pulses
P0377
Timing Reference High Resolution Signal B Too Few Pulses
P0378
Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
P0379
Timing Reference High Resolution Signal B No Pulses
P0380
Glow Plug/Heater Circuit "A" Malfunction
P0381
Glow Plug/Heater Indicator Circuit Malfunction
P0382
Glow Plug/Heater Circuit "B" Malfunction
P0385
Crankshaft Position Sensor B Circuit Malfunction
P0386
Crankshaft Position Sensor B Circuit Range/Performance
P0387
Crankshaft Position Sensor B Circuit Low Input
P0388
Crankshaft Position Sensor B Circuit High Input
P0389
Crankshaft Position Sensor B Circuit Intermittent
P0400
Exhaust Gas Recirculation Flow Malfunction
P0401
Exhaust Gas Recirculation Flow Insufficient Detected
P0402
Exhaust Gas Recirculation Flow Excessive Detected
P0403
Exhaust Gas Recirculation Circuit Malfunction
P0404
Exhaust Gas Recirculation Circuit Range/Performance
P0405
Exhaust Gas Recirculation Sensor A Circuit Low
P0406
Exhaust Gas Recirculation Sensor A Circuit High
P0407
Exhaust Gas Recirculation Sensor B Circuit Low
P0408
Exhaust Gas Recirculation Sensor B Circuit High
P0410
Secondary Air Injection System Malfunction
P0411
Secondary Air Injection System Incorrect Flow Detected
P0412
Secondary Air Injection System Switching Valve A Circuit Malfunction
P0413
Secondary Air Injection System Switching Valve A Circuit Open
P0414
Secondary Air Injection System Switching Valve A Circuit Shorted
P0415
Secondary Air Injection System Switching Valve B Circuit Malfunction
P0416
Secondary Air Injection System Switching Valve B Circuit Open
P0417
Secondary Air Injection System Switching Valve B Circuit Shorted
P0418
Secondary Air Injection System Relay "A" Circuit Malfunction
P0419
Secondary Air Injection System Relay "B" Circuit Malfunction
P0420
Catalyst System Efficiency Below Threshold (Bank 1)
P0421
Warm Up Catalyst Efficiency Below Threshold (Bank 1)
P0422
Main Catalyst Efficiency Below Threshold (Bank 1)
P0423
Heated Catalyst Efficiency Below Threshold (Bank 1)
P0424
Heated Catalyst Temperature Below Threshold (Bank 1)
P0430
Catalyst System Efficiency Below Threshold (Bank 2)
P0431
Warm Up Catalyst Efficiency Below Threshold (Bank 2)
P0432
Main Catalyst Efficiency Below Threshold (Bank 2)
P0433
Heated Catalyst Efficiency Below Threshold (Bank 2)
P0434
Heated Catalyst Temperature Below Threshold (Bank 2)
P0440
Evaporative Emission Control System Malfunction
P0441
Evaporative Emission Control System Incorrect Purge Flow
P0442
Evaporative Emission Control System Leak Detected (small leak)
P0443
Evaporative Emission Control System Purge Control Valve Circuit Malfunction
P0444
Evaporative Emission Control System Purge Control Valve Circuit Open
P0445
Evaporative Emission Control System Purge Control Valve Circuit Shorted
P0446
Evaporative Emission Control System Vent Control Circuit Malfunction
P0447
Evaporative Emission Control System Vent Control Circuit Open
P0448
Evaporative Emission Control System Vent Control Circuit Shorted
P0449
Evaporative Emission Control System Vent Valve/Solenoid Circuit Malfunction
P0450
Evaporative Emission Control System Pressure Sensor Malfunction
P0451
Evaporative Emission Control System Pressure Sensor Range/Performance
P0452
Evaporative Emission Control System Pressure Sensor Low Input
P0453
Evaporative Emission Control System Pressure Sensor High Input
P0454
Evaporative Emission Control System Pressure Sensor Intermittent
P0455
Evaporative Emission Control System Leak Detected (gross leak)
P0460
Fuel Level Sensor Circuit Malfunction
P0461
Fuel Level Sensor Circuit Range/Performance
P0462
Fuel Level Sensor Circuit Low Input
P0463
Fuel Level Sensor Circuit High Input
P0464
Fuel Level Sensor Circuit Intermittent
P0465
Purge Flow Sensor Circuit Malfunction
P0466
Purge Flow Sensor Circuit Range/Performance
P0467
Purge Flow Sensor Circuit Low Input
P0468
Purge Flow Sensor Circuit High Input
P0469
Purge Flow Sensor Circuit Intermittent
P0470
Exhaust Pressure Sensor Malfunction
P0471
Exhaust Pressure Sensor Range/Performance
P0472
Exhaust Pressure Sensor Low
P0473
Exhaust Pressure Sensor High
P0474
Exhaust Pressure Sensor Intermittent
P0475
Exhaust Pressure Control Valve Malfunction
P0476
Exhaust Pressure Control Valve Range/Performance
P0477
Exhaust Pressure Control Valve Low
P0478
Exhaust Pressure Control Valve High
P0479
Exhaust Pressure Control Valve Intermittent
P0480
Cooling Fan 1 Control Circuit Malfunction
P0481
Cooling Fan 2 Control Circuit Malfunction
P0482
Cooling Fan 3 Control Circuit Malfunction
P0483
Cooling Fan Rationality Check Malfunction
P0484
Cooling Fan Circuit Over Current
P0485
Cooling Fan Power/Ground Circuit Malfunction
P0500
Vehicle Speed Sensor Malfunction
P0501
Vehicle Speed Sensor Range/Performance
P0502
Vehicle Speed Sensor Low Input
P0503
Vehicle Speed Sensor Intermittent/Erratic/High
P0505
Idle Control System Malfunction
P0506
Idle Control System RPM Lower Than Expected
P0507
Idle Control System RPM Higher Than Expected
P0510
Closed Throttle Position Switch Malfunction
P0520
Engine Oil Pressure Sensor/Switch Circuit Malfunction
P0521
Engine Oil Pressure Sensor/Switch Circuit Range/Performance
P0522
Engine Oil Pressure Sensor/Switch Circuit Low Voltage
P0523
Engine Oil Pressure Sensor/Switch Circuit High Voltage
P0530
A/C Refrigerant Pressure Sensor Circuit Malfunction
P0531
A/C Refrigerant Pressure Sensor Circuit Range/Performance
P0532
A/C Refrigerant Pressure Sensor Circuit Low Input
P0533
A/C Refrigerant Pressure Sensor Circuit High Input
P0534
Air Conditioner Refrigerant Charge Loss
P0550
Power Steering Pressure Sensor Circuit Malfunction
P0551
Power Steering Pressure Sensor Circuit Range/Performance
P0552
Power Steering Pressure Sensor Circuit Low Input
P0553
Power Steering Pressure Sensor Circuit High Input
P0554
Power Steering Pressure Sensor Circuit Intermittent
P0560
System Voltage Malfunction
P0561
System Voltage Unstable
P0562
System Voltage Low
P0563
System Voltage High
P0565
Cruise Control On Signal Malfunction
P0566
Cruise Control Off Signal Malfunction
P0567
Cruise Control Resume Signal Malfunction
P0568
Cruise Control Set Signal Malfunction
P0569
Cruise Control Coast Signal Malfunction
P0570
Cruise Control Accel Signal Malfunction
P0571
Cruise Control/Brake Switch A Circuit Malfunction
P0572
Cruise Control/Brake Switch A Circuit Low
P0573
Cruise Control/Brake Switch A Circuit High
P0574
Cruise Control Related Malfunction
P0575
P0576
P0577
P0578
P0579
P0580
P0600
Serial Communication Link Malfunction
P0601
Internal Control Module Memory Check Sum Error
P0602
Control Module Programming Error
P0603
Internal Control Module Keep Alive Memory (KAM) Error
P0604
Internal Control Module Random Access Memory (RAM) Error
P0605
Internal Control Module Read Only Memory (ROM) Error
P0606
PCM Processor Fault
P0608
Control Module VSS Output "A" Malfunction
P0609
Control Module VSS Output "B" Malfunction
P0620
Generator Control Circuit Malfunction
P0621
Generator Lamp "L" Control Circuit Malfunction
P0622
Generator Field "F" Control Circuit Malfunction
P0650
Malfunction Indicator Lamp (MIL) Control Circuit Malfunction
P0654
Engine RPM Output Circuit Malfunction
P0655
Engine Hot Lamp Output Control Circuit Malfucntion
P0656
Fuel Level Output Circuit Malfunction
P0700
Transmission Control System Malfunction
P0701
Transmission Control System Range/Performance
P0702
Transmission Control System Electrical
P0703
Torque Converter/Brake Switch B Circuit Malfunction
P0704
Clutch Switch Input Circuit Malfunction
P0705
Transmission Range Sensor Circuit malfunction (PRNDL Input)
P0706
Transmission Range Sensor Circuit Range/Performance
P0707
Transmission Range Sensor Circuit Low Input
P0708
Transmission Range Sensor Circuit High Input
P0709
Transmission Range Sensor Circuit Intermittent
P0710
Transmission Fluid Temperature Sensor Circuit Malfunction
P0711
Transmission Fluid Temperature Sensor Circuit Range/Performance
P0712
Transmission Fluid Temperature Sensor Circuit Low Input
P0713
Transmission Fluid Temperature Sensor Circuit High Input
P0714
Transmission Fluid Temperature Sensor Circuit Intermittent
P0715
Input/Turbine Speed Sensor Circuit Malfunction
P0716
Input/Turbine Speed Sensor Circuit Range/Performance
P0717
Input/Turbine Speed Sensor Circuit No Signal
P0718
Input/Turbine Speed Sensor Circuit Intermittent
P0719
Torque Converter/Brake Switch B Circuit Low
P0720
Output Speed Sensor Circuit Malfunction
P0721
Output Speed Sensor Range/Performance
P0722
Output Speed Sensor No Signal
P0723
Output Speed Sensor Intermittent
P0724
Torque Converter/Brake Switch B Circuit High
P0725
Engine Speed input Circuit Malfunction
P0726
P0727
P0728
P0730
Incorrect Gear Ratio
P0731
Gear 1 Incorrect ratio
P0732
Gear 2 Incorrect ratio
P0733
Gear 3 Incorrect ratio
P0734
Gear 4 Incorrect ratio
P0735
Gear 5 Incorrect ratio
P0736
Reverse incorrect gear ratio
P0740
Torque Converter Clutch Circuit Malfuction
P0741
Torque Converter Clutch Circuit Performance or Stuck Off
P0742
Torque Converter Clutch Circuit Stuck On
P0743
Torque Converter Clutch Circuit Electrical
P0744
Torque Converter Clutch Circuit Intermittent
P0745
Pressure Control Solenoid Malfunction
P0746
Pressure Control Solenoid Performance or Stuck Off
P0747
Pressure Control Solenoid Stuck On
P0748
Pressure Control Solenoid Electrical
P0749
Pressure Control Solenoid Intermittent
P0750
Shift Solenoid A Malfunction
P0751
Shift Solenoid A Performance or Stuck Off
P0752
Shift Solenoid A Stuck On
P0753
Shift Solenoid A Electrical
P0754
Shift Solenoid A Intermittent
P0755
Shift Solenoid B Malfunction
P0756
Shift Solenoid B Performance or Stuck Off
P0757
Shift Solenoid B Stuck On
P0758
Shift Solenoid B Electrical
P0759
Shift Solenoid B Intermittent
P0760
Shift Solenoid C Malfunction
P0761
Shift Solenoid C Performance or Stuck Off
P0762
Shift Solenoid C Stuck On
P0763
Shift Solenoid C Electrical
P0764
Shift Solenoid C Intermittent
P0765
Shift Solenoid D Malfunction
P0766
Shift Solenoid D Performance or Stuck Off
P0767
Shift Solenoid D Stuck On
P0768
Shift Solenoid D Electrical
P0769
Shift Solenoid D Intermittent
P0770
Shift Solenoid E Malfunction
P0771
Shift Solenoid E Performance or Stuck Off
P0772
Shift Solenoid E Stuck On
P0773
Shift Solenoid E Electrical
P0774
Shift Solenoid E Intermittent
P0780
Shift Malfunction
P0781
1-2 Shift Malfunction
P0782
2-3 Shift Malfunction
P0783
3-4 Shift Malfunction
P0784
4-5 Shift Malfunction
P0785
Shift/Timing Solenoid Malfunction
P0786
Shift/Timing Solenoid Range/Performance
P0787
Shift/Timing Solenoid Low
P0788
Shift/Timing Solenoid High
P0789
Shift/Timing Solenoid Intermittent
P0790
Normal/Performance Switch Circuit Malfunction
P0801
Reverse Inhibit Control Circuit Malfunction
P0803
1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
P0804
1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
P1106
Manifold Absolute Pressure (MAP) sensor circuit intermittent high voltage
P1107
Manifold Absolute Pressure (MAP) sensor circuit intermittent low voltage
P1108
BARO to MAP signal circuit comparison too high
P1111
Intake Air Temperature (IAT) sensor intermittent high voltage
P1112
Intake Air Temperature (IAT) sensor intermittent low voltage
P1114
Engine Coolant Temperature (ECT) sensor circuit intermittent low voltage
P1115
Engine Coolant Temperature (ECT) sensor circuit intermittent high voltage
P1121
Throttle Position (TP) sensor inconsistent with MAF Sensor high voltage
P1122
Throttle Position (TP) sensor inconsistent with MAF Sensor low voltage
P1133
Heated Oxygen Sensor (HO2S) insufficient switching bank 1 sensor 1 (Rear Bank)
P1134
Heated Oxygen Sensor (HO2S) transition time ratio bank 1 sensor 1 (Rear Bank)
P1153
Heated Oxygen Sensor (HO2S) insufficient switching bank 2 sensor 1 (Front Bank)
P1154
Heated Oxygen Sensor (HO2S) transition time ratio bank 2 sensor 1 (Front Bank)
P1189
Engine Oil Pressure Switch Circuit
P1258
Engine Metal Over Temperature Protection
P1320
Ignition Control (IC) Module 4x Reference Circuit Intermittent No Pulses
P1323
Ignition Control (IC) Module 24x Reference Circuit low frequency
P1350
Ignition Control System
P1370
Ignition Control (IC) Module 4x Reference too many pulses
P1371
Ignition Control (IC) Module 4x Reference too few pulses
P1375
Ignition Control (IC) Module 24x Reference High Voltage
P1376
Ignition Ground Circuit
P1377
Ignition Control (IC) Module Cam Pulse to 4x Reference Pulse Comparison
P1380
EBTCM DTC Detected-Rough Data Unusable
P1381
Misfire Detected-No EBTCM/PCM Serial Data
P1404
Exhaust Gas Recirculation (EGR) Valve Pintle Stuck Open
P1441
Evaporative System Flow During Non-Purge
P1483
Engine Cooling System Performance
P1508
Idle Air Control (IAC) System -Low RPM
P1520
Intake Manifold Runner Control (IMRC) circuit malfunction
P1524
Throttle Position (TP) Sensor Learned Closed Throttle Angle Degrees Out-Of-Range
P1527
Trans Range / Pressure Switch Comparison
P1554
Cruise Engaged Circuit High Voltage
P1560
Cruise Control System-Transaxle Not in Drive
P1564
Cruise Control System-Vehicle Acceleration too high
P1566
Cruise Control System-Engine RPM Too High
P1567
Cruise Control- ABCS Active
P1570
Cruise Control System - Traction Control Active
P1571
Traction Control System PWM Circuit No Frequency
P1574
EBTCM System- Stop Lamp Switch Circuit High Voltage
P1575
Extended Travel Brake Switch Circuit High Voltage
P1579
Park/Neutral to Drive/Reverse At high Throttle Angle
P1599
Engine Stall or Near Stall Detected
P1602
Loss of EBTCM Serial Data
P1603
Loss of SDM Serial Data
P1604
Loss of IPC Serial Data
P1605
Loss of HVACC Serial Data
P1610
Loss of PZM Serial Data
P1611
Loss of CVRTD Serial Data
P1617
Engine Oil Level Switch Circuit
P1621
PCM Memory Performance
P1626
Theft Deterrent System - Fuel Enable Circuit
P1630
Theft Deterrent - PCM in Learn Mode
P1631
Theft Deterrent - Password Incorrect
P1632
Theft Deterrent - Fuel Disabled
P1633
Ignition Supplement Power Circuit Low Voltage
P1634
Ignition 1 Power Circuit Low Voltage
P1640
Driver 1 - Input High Voltage
P1641
P1642
Vehicle Speed Output Circuit
P1644
Delivered Torque Output Circuit
P1645
EVAP Solenoid Output Circuit
P1646
EVAP Vent Valve Output Circuit
P1650
Driver 2 - Input High Voltage
P1652
Lift/Dive Circuit
P1654
Cruise Disable Output Circuit
P1660
Cooling Fan Control Circuits
[Modified by RotaryBzzz, 10:31 AM 1/17/2003]
P0100
P0101
P0102
P0103
P0104
P0105
P0106
P0107
P0108
P0109
P0110
P0111
P0112
P0113
P0114
P0115
P0116
P0117
P0118
P0119
P0120
P0121
P0122
P0123
P0124
P0125
P0126
P0130
P0131
P0132
P0133
P0134
P0135
P0136
P0137
P0138
P0139
P0140
P0141
P0142
P0143
P0144
P0145
P0146
P0147
P0150
P0151
P0152
P0153
P0154
P0155
P0156
P0157
P0158
P0159
P0160
P0161
P0162
P0163
P0164
P0165
P0166
P0167
P0170
P0171
P0172
P0173
P0174
P0175
P0176
P0177
P0178
P0179
P0180
P0181
P0182
P0183
P0184
P0185
P0186
P0187
P0188
P0189
P0190
P0191
P0192
P0193
P0194
P0195
P0196
P0197
P0198
P0199
P0200
P0201
P0202
P0203
P0204
P0205
P0206
P0207
P0208
P0209
P0210
P0211
P0212
P0213
P0214
P0215
P0216
P0217
P0218
P0219
P0220
P0221
P0222
P0223
P0224
P0225
P0226
P0227
P0228
P0229
P0230
P0231
P0232
P0233
P0234
P0235
P0236
P0237
P0238
P0239
P0240
P0241
P0242
P0243
P0244
P0245
P0246
P0247
P0248
P0249
P0250
P0251
P0252
P0253
P0254
P0255
P0256
P0257
P0258
P0259
P0260
P0261
P0262
P0263
P0264
P0265
P0266
P0267
P0268
P0269
P0270
P0271
P0272
P0273
P0274
P0275
P0276
P0277
P0278
P0279
P0280
P0281
P0282
P0283
P0284
P0285
P0286
P0287
P0288
P0289
P0290
P0291
P0292
P0293
P0294
P0295
P0296
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P0307
P0308
P0309
P0311
P0312
P0320
P0321
P0322
P0323
P0325
P0326
P0327
P0328
P0329
P0330
P0331
P0332
P0333
P0334
P0335
P0336
P0337
P0338
P0339
P0340
P0341
P0342
P0343
P0344
P0350
P0351
P0352
P0353
P0354
P0355
P0356
P0357
P0358
P0359
P0360
P0361
P0362
P0370
P0371
P0372
P0373
P0374
P0375
P0376
P0377
P0378
P0379
P0380
P0381
P0382
P0385
P0386
P0387
P0388
P0389
P0400
P0401
P0402
P0403
P0404
P0405
P0406
P0407
P0408
P0410
P0411
P0412
P0413
P0414
P0415
P0416
P0417
P0418
P0419
P0420
P0421
P0422
P0423
P0424
P0430
P0431
P0432
P0433
P0434
P0440
P0441
P0442
P0443
P0444
P0445
P0446
P0447
P0448
P0449
P0450
P0451
P0452
P0453
P0454
P0455
P0460
P0461
P0462
P0463
P0464
P0465
P0466
P0467
P0468
P0469
P0470
P0471
P0472
P0473
P0474
P0475
P0476
P0477
P0478
P0479
P0480
P0481
P0482
P0483
P0484
P0485
P0500
P0501
P0502
P0503
P0505
P0506
P0507
P0510
P0520
P0521
P0522
P0523
P0530
P0531
P0532
P0533
P0534
P0550
P0551
P0552
P0553
P0554
P0560
P0561
P0562
System Voltage Low
P0563
System Voltage High
P0565
P0566
P0567
P0568
P0569
P0570
P0571
P0572
P0573
P0574
P0575
P0576
P0577
P0578
P0579
P0580
P0600
P0601
P0602
P0603
P0604
P0605
P0606
PCM Processor Fault
P0608
P0609
P0620
P0621
P0622
P0650
P0654
P0655
P0656
P0700
P0701
P0702
P0703
P0704
P0705
P0706
P0707
P0708
P0709
P0710
P0711
P0712
P0713
P0714
P0715
P0716
P0717
P0718
P0719
P0720
P0721
P0722
P0723
P0724
P0725
P0726
P0727
P0728
P0730
P0731
P0732
P0733
P0734
P0735
P0736
P0740
P0741
P0742
P0743
P0744
P0745
P0746
P0747
P0748
P0749
P0750
P0751
P0752
P0753
P0754
P0755
P0756
P0757
P0758
P0759
P0760
P0761
P0762
P0763
P0764
P0765
P0766
P0767
P0768
P0769
P0770
P0771
P0772
P0773
P0774
P0780
Shift Malfunction
P0781
P0782
P0783
P0784
P0785
P0786
P0787
P0788
P0789
P0790
P0801
P0803
P0804
P1106
P1107
P1108
P1111
P1112
P1114
P1115
P1121
P1122
P1133
P1134
P1153
P1154
P1189
P1258
P1320
P1323
P1350
P1370
P1371
P1375
P1376
P1377
P1380
P1381
P1404
P1441
P1483
P1508
P1520
P1524
P1527
P1554
P1560
P1564
P1566
P1567
P1570
P1571
P1574
P1575
P1579
P1599
P1602
P1603
P1604
P1605
P1610
P1611
P1617
P1621
P1626
P1630
P1631
P1632
P1633
P1634
P1640
P1641
P1642
P1644
P1645
P1646
P1650
P1652
Lift/Dive Circuit
P1654
P1660
Re: OBD II : Complete Codes for your OBD II Reader - linked (RotaryBzzz)
now we just need a guide to how to fix it lol
nothing worst then knowing your code and trying to see what caused it
Re: OBD II : Complete Codes for your OBD II Reader - linked (KTeller8)
I get this one all the time
"P0212
Injector Circuit Malfunction - Cylinder 12 "
Damn OBDII Ferrari
"P0212
Damn OBDII Ferrari
Re: OBD II : Complete Codes for your OBD II Reader - linked (RaceTilIDie)
OBD II reader's range from $100-4000 new. Here's some cheap ones:
oops: the link isn't displaying correctly...
search ebay for "OBD II reader" and you'll pull a couple
[Modified by RotaryBzzz, 9:52 AM 1/17/2003]
YEah, I was looking at the Auto Xray for $200. But I was thinkin I could make one much cheaper. It can't be that complicated, I just don't know if anyone has done this here yet.
It can graph and log lots of different data from sensors on your motor too. Pretty sweet.
Re: OBD II : Complete Codes for your OBD II Reader - linked (YumVTEC)
y friend has software and a cable he purchased for his palm pilot that enable it to plug into your obd2 diag port and pull the codes, even reset the ecu while the motor is running. it's called pocket logger. http://www.pocketlogger.com
Justin Olson
Welding / Fabrication
25
01-19-2006 05:11 PM
