96 H22 Swap questions............... again
I NEED SOME ENGINE HElp about my Accord
I have a 1996 accord ex with a f18B (thats bad. it has very little potenial.)
I would like to buy a jdm h22 or h22a engine to put in there.BUt i am wondering if when i am buying the engine should look for everything
h22a,buy new engine mounts and axels for a honda prelude,ecu,odb or odb2 (whats the difference?)5 speed hydraulic transmission, wiring harness, alternator, manifolds, motor mounts, sensors.
CAN U PLEASE TELL ALL THE PARTS THAT I AM GOING TO NEED FOR THE SWAP?
CAN u tell me where can i buy it(engine to) in miami or houston?
Re: I NEED SOME ENGINE HElp about my Accord (Eclipse)
search is your best friend. but to help you a little bit: buy the engine/trans/ecu, you use same mounts, use your accord axles, if your 5spd already you can use your shifter/linkage, but prelude shifter/lingage is better, your obdII, so I suggest you stick obdII, or go obdI and buy a conv. harness, use your harness (add wires necessary), use prelude intake, header, accord exhaust. That should be enough to get you started...
Re: I NEED SOME ENGINE HElp about my Accord (johnsaccord)
hit me on email
mkteller8@aol.com
i did my swap and can shade some light on some ideas if you need help
mkteller8@aol.com
stackz
04-16-2004 02:17 PM
