engine revving by itself
Old Feb 14, 2003 | 09:10 PM
jokerstud's Avatar
Default engine revving by itself
My brother's car, the 94 accord ex in my profile, manual transmission. The question I have is about the engine reving. I couldn't look at it myself, or dont have the knowledge because I am at school and he is home so I just heard this from him and was looking for ideas. He says that when its in neutral, either sometimes at a light or usually when its parked and running the RPM's will go from like 1k to 1.5k or 2k and then back down a few times and then it will stop. He thinks its sparatic with temperature but he isnt sure. Could this be a temperature thing? he is in syracuse NY and its has been snowing for like 40 days straight and been cold. Or any other ideas? TIA!!!
Old Feb 14, 2003 | 11:14 PM
iam7head's Avatar
Default Re: engine revving by itself (jokerstud)
did you take a good look at the TB?
did the cable stuck?
Old Feb 15, 2003 | 03:31 AM
sauceman's Avatar
Did you get any error codes from your ECU?
Is the car misfiring, backfiring a lot on compression?
If so, it could be your distributor going bad.
Old Feb 15, 2003 | 07:22 AM
98AccordEX's Avatar
check the EGR valve
Old Feb 15, 2003 | 08:40 AM
GZERO's Avatar
faulty FITV (or FIV)??
Faulty IAC
Old Feb 15, 2003 | 09:00 AM
jokerstud's Avatar
Default Re: engine revving by itself (GZERO)
damn, I can't do anything while im here at school and he is too dumb to even check his own oil. Think it will be ok to leave it for a while until I get home or is he gonna have to go to the DEALER! ahhhh
Old Feb 15, 2003 | 06:43 PM
Crono139's Avatar
The throttle body cable is probably stuck. Either that, or you guys are recreating the movie Maximum Overdrive. You know, the one with Emilio Estevez, where all of the electrical appliances go wild, and cars, and trucks act on their own.
Old Feb 16, 2003 | 08:37 AM
98AccordEX's Avatar
Default Re: engine revving by itself (Crono139)
if the throttle cable was stuck then it would just stay at 2000. not just keep jumping up and down. i am telling you man. its the EGR valve
Old Feb 19, 2003 | 12:30 PM
professorman's Avatar
Default Re: engine revving by itself (98AccordEX)
yeah, it probably is the valve. my integra did that when it was in an accident and the radiator was busted
Old Feb 19, 2003 | 03:24 PM
raceACCORDingly's Avatar
Default Re: engine revving by itself (profroopchan)
loose vacuum or faulty tps?
Old Feb 19, 2003 | 05:50 PM
BigChris's Avatar
I have the same problem. Its my IAT sensor. Before you go changing it, check for vacuum leaks.
usshrpr
Sep 18, 2018 07:02 AM
giovannie23
Jul 2, 2014 08:18 AM
jorgep82
Nov 18, 2013 12:15 AM
tarheels1
Jan 17, 2010 06:38 PM
chagonio
Jan 23, 2008 02:57 PM
