another weird problem.
Old Mar 16, 2003 | 04:26 AM
brimy311's Avatar
Default another weird problem.
i have an 86 honda accord, it drives normal when accelerating, but as soon as you let off hte accelorator it will spudder and not let you get going again until you slow down to like 5mph, then it will let you accerate normal again, but you can never stop accelerating or you will have to pull off until you are doing 5mph or so....any ideas? btw: the engine light is not on, so there is no code showing
Old Mar 16, 2003 | 04:36 AM
niedejb's Avatar
Default Re: another weird problem. (brimy311)
Try changing your plugs.
At higher rpms the coil doesnt have as much time to charge before firing. If your plugs are bad it makes this even worse.
Old Mar 16, 2003 | 05:13 AM
brimy311's Avatar
oh good call, let me check them out and see what i have going on there...
Old Mar 17, 2003 | 07:38 AM
NeedFoSpeed's Avatar
i know for a fact it is the plugs. My 87 accord was doing that and i changed all the plugs, plug wires. and coil. and problem was solved.
metrowerk
Dec 31, 2018 03:59 AM
Kamil Dylewski
Apr 24, 2017 12:41 AM
05hondagirl
Honda Civic (2001 - 2005)
Sep 23, 2013 08:46 AM
jdm.fanatic
Sep 26, 2009 05:14 AM
osuperjohno
Dec 10, 2004 10:36 AM
