firing order
Old Apr 17, 2003 | 05:41 PM
sailor's Avatar
Default firing order
guys whats the firing order on a 97accord 2.2 not vtec???
Old Apr 17, 2003 | 06:19 PM
Chiovnidca's Avatar
Default Re: firing order (sailor)
1342
Old Apr 17, 2003 | 06:40 PM
sailor's Avatar
how to adjust timing?
Old Apr 17, 2003 | 07:08 PM
Nick H's Avatar
New User
pull the little dial outwards on your watch, turn it until it says the current time (whcih is 10:08 right now) and then push it back in...oh, wrong timing
Old Apr 17, 2003 | 07:16 PM
H23 Power's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sailor &raquo;</TD></TR><TR><TD CLASS="quote">how to adjust timing?</TD></TR></TABLE>
rotate distributor...
towards fire wall to advance
away to retard
use a timing gun to tell you what its set at
Old Apr 18, 2003 | 04:56 AM
jweller's Avatar
Default Re: firing order (H23 Power)
correct me if I'm wrong, but since a 97 is OBD2, isn't the timing non-adjustable.
Old Apr 18, 2003 | 06:12 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: firing order (jweller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jweller &raquo;</TD></TR><TR><TD CLASS="quote">correct me if I'm wrong, but since a 97 is OBD2, isn't the timing non-adjustable.</TD></TR></TABLE>
Thats what I thought.
Old Apr 18, 2003 | 06:18 AM
sauceman's Avatar
That's exact.
The ECU takes care of it.
Old Apr 18, 2003 | 06:30 AM
sailor's Avatar
Default Re: firing order (Nick H)
stfu funny man
Old Apr 18, 2003 | 06:31 AM
sailor's Avatar
wel it states in my chiltons manual that you can adjust it.
Old Apr 18, 2003 | 07:18 AM
JimBlake's Avatar
Well, if your Chiltons is right, then you should be able to loosen the distributor mounting bolts & twist it. Try it & see. If not, then (gawsh) the book was wrong.
If it's adjustable, the distributor has slots for the mounting bolts so there's room to twist it. If the timing is controlled by the crankshaft sensor, then even if there were slots, it wouldn't actually change the timing anyway.
Old Apr 18, 2003 | 07:25 AM
GZERO's Avatar
not sure if this is only for OBD1 cars, but if you jump the service connector, turn the car on and change the timming it will be keep the way you set it at
Old Apr 18, 2003 | 08:14 AM
sailor's Avatar
Default Re: firing order (GZERO)
how do i do that?
Old Apr 18, 2003 | 08:47 AM
GZERO's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sailor &raquo;</TD></TR><TR><TD CLASS="quote">how do i do that?</TD></TR></TABLE>
how do you do what? i just told you how, would you care to be more specific?
Old Apr 18, 2003 | 11:17 AM
sailor's Avatar
the service connector thingee for the timin
Old Apr 18, 2003 | 12:08 PM
JimBlake's Avatar
The service connector is the same thing that you use to check CEL codes. Stuffed up somewhere between the glovebox & the kick-panel, usually held in a green rubber thing... It's like that in my '95 GS-R, I don't know if Accord is the same.
http://www.c-speedracing.com/faq/06.php
When you jumper the wires in that connector, the ECM knows its not supposeed to try adjusting the timing. Then you get your timing gun & have at it.
The next question is... whether your timing is actually adjustable, like what people are saying in the other thread.
Old Apr 18, 2003 | 12:36 PM
Chiovnidca's Avatar
Warm up engine. Jump the service check connector. Hook up timing light and adjust. Stock timing is 15+-2 at 700+-50RPMs.
Old Apr 18, 2003 | 12:38 PM
Chiovnidca's Avatar
Default Re: firing order (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">
Yes it is adjustable.
Old Apr 18, 2003 | 03:35 PM
sailor's Avatar
Default Re: firing order (TurboD16Chiovnidca)
ok what actually are the procedures to adjusting the timing with the light? new at this.
Old Apr 18, 2003 | 04:32 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sailor &raquo;</TD></TR><TR><TD CLASS="quote">ok what actually are the procedures to adjusting the timing with the light? new at this.</TD></TR></TABLE>
Look up about 3 posts.
Old Apr 18, 2003 | 06:23 PM
sailor's Avatar
how do i hook up timing lite and adjust????? wat are the step by step procedures.???
Old Apr 21, 2003 | 04:36 AM
JimBlake's Avatar
Timing lights usually come with instructions. Most often, you have clips that you put on the battery posts to power the light. Then for a trigger signal, there's usually a clamp that goes around your #1 spark plug wire.
Each time #1 fires, the light flashes. Shine it onto your crankshaft pulley & it 'freezes' the position of the timing marks when it flashes. Loosen the distributor mounting bolts & twist the distributor to adjust the timing. When you get it where you want it, tighten the bolts & check it again to make sure.
Old Apr 21, 2003 | 06:48 AM
sailor's Avatar
theres not much room to turn the dist on the 97accord 2.2. should i turn it with the car on? sorry im new at this.
Old Apr 21, 2003 | 06:58 AM
JimBlake's Avatar
On my '95 Integra the mounting bolts are in obvious slots about 3/4" long, so you can spin the distributor a lot. My '98 Accord has holes just big enough for the bolts, so you can't hardly spin it at all. That's what I meant when I said yours might not be adjustable. The distributor that can't spin probably goes along with the crank sensor, on OBD-II cars that have non-adjustable spark timing.
Yes, turn it with the engine on, just don't get shocked by the ignition wires. If you have a pacemaker or something like that, you should turn off the engine to adjust since even a light shock would be a really bad thing.
Old Apr 21, 2003 | 07:21 PM
sailor's Avatar
does the crank does not spin automatically when the engine is on? or can i jus turn it?
