max boost?
Old Apr 12, 2003 | 09:44 AM
HRC51's Avatar
Default max boost?
anybody have a rough idea of how much boost a stock h22 can handle for daily driving before the ring lands give out? 10 psi or less?
Old Apr 12, 2003 | 10:35 AM
iam7head's Avatar
Default Re: max boost? (SOHCitTOme)
what kinda of internal?
built?
Old Apr 12, 2003 | 11:14 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCitTOme &raquo;</TD></TR><TR><TD CLASS="quote"> stock</TD></TR></TABLE>
Old Apr 12, 2003 | 12:07 PM
Stew Pidasso's Avatar
Default Re: max boost? (TurboD16Chiovnidca)
8lbs is safe for daily driving. 10-12 lbs if you have a standalone (hondata or AEM) with excellent tuning.
Old Apr 12, 2003 | 11:20 PM
Okley_01's Avatar
Default Re: max boost? (Stew Pidasso)
hmmm, i would say 6 max daily driver, especially if its JDM cause i believe those are higher compression. if you go much higher, your probably going to run into problems.
Old Apr 12, 2003 | 11:39 PM
Brandon's Avatar
Life is Suffering
Default Re: max boost? (Okley_01)
It all depends on your fuel setup. With a set of 450's and an SMC/VAFC, I wouldn't go over 8psi. With a decent "stand-alone" you could easily crank it up to 14psi.
Old Apr 14, 2003 | 04:26 AM
Default Re: max boost? (CD7)
The JDM does have higher compression but with proper tuning higher boost isn't a problem. Just get it tuned on a dyno.
Old Apr 14, 2003 | 01:00 PM
biggs2.3's Avatar
you should just build the motor
Old Apr 14, 2003 | 08:48 PM
Okley_01's Avatar
Default Re: (SOHCitTOme)
so yeah, if you want to go cheap, retard the timming a few degrees, find a Vortech FMU on e-bay or something, and boost 5-6 psi. but make sure you have the right kind of turbo, like for example a Garett T3/TO4E. Your not going to want a smaller turbo cause a higher compression engine like yours is going to rely on a greater mass of air, so make sure you keep that in mind.
btw, if your interested, check out the turbo here:
https://honda-tech.com/zerothread?id=468082
teddy_dc2
Aug 6, 2006 07:10 AM
one slow coupe
Mar 19, 2006 05:52 PM
89civicsiB18B
May 14, 2005 07:56 AM
9341civic
Apr 2, 2005 12:16 AM
Wrath of VTEC
Sep 15, 2003 06:58 PM
