vss sensor
Old Apr 18, 2004 | 12:07 AM
topspeed02's Avatar
Default vss sensor
hey guys im having a problem with my VSS sensor and vtec. Today i changed the sensor and it worked ok for about 20min or so then i laid into 3rd gear good and my neadle started bouncing around again like it did when i first got the problem . Which also means vtec will not engage. Just bout part from honda and it doesnt even move my speedo anymore. Can anyone help me with this problem im having?
Old Apr 18, 2004 | 06:49 AM
Chiovnidca's Avatar
Default Re: vss sensor (topspeed02)
Are the connector pins at the VSS corroded? What year and model?
Old Apr 18, 2004 | 10:37 AM
topspeed02's Avatar
its a 95 i changed the pins on one of them cause it pulled out of the connection. my friend extended the wires so it wont pull out again.
Old Apr 18, 2004 | 12:05 PM
Chiovnidca's Avatar
Default Re: (topspeed02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed02 &raquo;</TD></TR><TR><TD CLASS="quote">its a 95 </TD></TR></TABLE>
Has the CEL been coming on? I don't see many bad speed sensors on 94-97 Accords. Usually a bad speedo head on them.
Old Apr 18, 2004 | 09:13 PM
topspeed02's Avatar
Yes check engine light comes on with code 17. And I have no vtec or cruise control and the part was brand new form Honda.
Old Apr 19, 2004 | 03:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by topspeed02 &raquo;</TD></TR><TR><TD CLASS="quote">Yes check engine light comes on with code 17. And I have no vtec or cruise control and the part was brand new form Honda.</TD></TR></TABLE>
If the VSS is good, there's a wiring or connector problem somewhere.
DC2man
Mar 3, 2008 07:01 PM
ricearoni56
Feb 11, 2008 05:10 PM
686_ef
11
Apr 6, 2005 05:57 PM
jaydm ferio
11
Dec 13, 2004 07:19 PM
RAS Motorsports
Oct 15, 2004 10:44 AM
