help please!
Old Apr 21, 2004 | 08:05 PM
josh0855's Avatar
Default help please!
On my 1995 Accord (auto) when I am in drive and accelerate my car hesitates. What I mean is there is no power and the revs don’t register properly. When the power delivery does happen it is in the form of a jolt not smooth power delivery. You can compare what is happening to say a “Lugged” engine when the gears are just not shifting in sync. Can anyone help or give suggestions I would really appreciate it.
THANK YOU.
Old Apr 21, 2004 | 08:07 PM
-RedneckDave-'s Avatar
Working
Default Re: help please! (josh0855)
Sounds like your transmission is going out.
Old Apr 22, 2004 | 12:02 AM
versatyle's Avatar
maybe ur clutch is slipping?...pick up a haynes manual they have a troubleshoot guide in there and it will give some sort of idea!
Old Apr 22, 2004 | 12:05 AM
accordingly's Avatar
Default Re: help please! (versatyle)
torque converter or injecters is what i would check first. if those are good then move on to plugs and wires and filters.
im having kinda the same problem with mine but its not as extreme as yours
Old Apr 22, 2004 | 07:32 AM
jfastman's Avatar
This is going to be a famous quote on this site- Check the basics first. Inspect the secondary igntion system (plugs, wires, dizzy cap and rotor), igition timing, fuel pressure and delivery volume, engine cranking and running compression and valve adjustment. If all of these things check out ok, go looking for other problems in the powertrain or drivetrain.
Old Apr 22, 2004 | 07:47 AM
Working
Default Re: help please! (accordingly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jfastman &raquo;</TD></TR><TR><TD CLASS="quote">This is going to be a famous quote on this site- Check the basics first. Inspect the secondary igntion system (plugs, wires, dizzy cap and rotor), igition timing, fuel pressure and delivery volume, engine cranking and running compression and valve adjustment. If all of these things check out ok, go looking for other problems in the powertrain or drivetrain. </TD></TR></TABLE> Worthless post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by versatyle &raquo;</TD></TR><TR><TD CLASS="quote">maybe ur clutch is slipping?...pick up a haynes manual they have a troubleshoot guide in there and it will give some sort of idea!</TD></TR></TABLE>
Where the hell are you from cause it clearly states that it is an auto and the is no clutch in an auto. well done.
I still say it is the transmission but you could try and have a tranny flush to see if that helps.
Old Apr 22, 2004 | 08:19 AM
jfastman's Avatar
Default Re: help please! (01accordv6)
Whattya mean worthless. It doesn't help to guess what's wrong intill you know all the basic things ar all in good working order!
Old Apr 22, 2004 | 08:30 AM
jfastman's Avatar
The tranny aint gunna work right if the engine aint runnin right. Ya think?
Old Apr 22, 2004 | 08:31 AM
Working
Default Re: help please! (jfastman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by josh0855 &raquo;</TD></TR><TR><TD CLASS="quote">On my 1995 Accord (auto) when I am in drive and accelerate my car hesitates. What I mean is there is no power and the revs don’t register properly. When the power delivery does happen it is in the form of a jolt not smooth power delivery. You can compare what is happening to say a “Lugged” engine when the gears are just not shifting in sync. Can anyone help or give suggestions I would really appreciate it.
THANK YOU.
Sounds like it is running to me i.e. when i am in drive and accelerate
Old Apr 22, 2004 | 08:39 AM
jfastman's Avatar
yea but it also says it hesitates. What's the hesitation caused by???
Old Apr 22, 2004 | 10:56 AM
Working
It is caused by the torque converter going bad or poor pressure in the system.
Old Apr 22, 2004 | 03:25 PM
jfastman's Avatar
ya gotta check line pressure to know that and that's part of doin the BASICS!!!
Old Apr 22, 2004 | 08:24 PM
Working
Ok smart *** you have said to check the basics almost ten times and i understand that you are trying to keep him from spending tons of money by replacing the trans. but you are just being annoying and everything you have said should have been the things he checked before coming on here and asked.
Old Apr 23, 2004 | 06:16 AM
jfastman's Avatar
its better to be a smart *** than a dumb ***! LOL
Old Apr 23, 2004 | 06:27 AM
Working
I seriously hope you are not calling me a dumb ***.
Old Apr 23, 2004 | 06:49 AM
jfastman's Avatar
how long ya wanna drag this out?
Old Apr 23, 2004 | 01:26 PM
Working
what is your deal you noob as bitch.
Old Apr 23, 2004 | 01:29 PM
jfastman's Avatar
OK so now ill call you a dumb ***. Dumb ***!
Old Apr 23, 2004 | 01:31 PM
Working
I am done with this you are just a troll wanting to start trouble.
Old Apr 23, 2004 | 01:47 PM
jfastman's Avatar
Me startin' trouble, maybe it's all just a misunderstanding? Truce ahight?
Old Apr 23, 2004 | 01:53 PM
.bagged's Avatar
HOly ****..what was the topic?
Old Apr 30, 2004 | 07:16 PM
josh0855's Avatar
Default Re: help please! (baGged93aCcord)
...i wonder if we are getting off topic... I would really appricate some more constructive sugestions I am running out of ideas with my car
Old Apr 30, 2004 | 07:21 PM
josh0855's Avatar
about how much would it be for a new torque converter installed?
Old May 1, 2004 | 08:49 AM
FatJoe's Avatar
you could find a new tranny to install for a total of around 200 bucks or less if you look. try going to ur local junkyard and see what they have. that or look here on honda-tech in the classifieds. why tear a tranny apart and fix it when you can just get a better one and install it no problem?
oh and by the way jfastman... dont talk to 01accordv6 like that... Offical ****** rule all.... YYYyyyEEEeeeAAAAAaaaaHHHHhhhh!!!!
Old May 1, 2004 | 01:00 PM
jakeiscool's Avatar
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01accordv6 &raquo;</TD></TR><TR><TD CLASS="quote"> Worthless post.
Im clapping right now
