Diagnostic error code P1167
Old Sep 22, 2004 | 06:11 PM
shalemain's Avatar
Default Diagnostic error code P1167
The code reader says its the manufacturer fuel air mixture, I don't see an airflow meter on the car. I checked my chilton manual but this code is not listed and I did clear the error and change the oxygen sensor but the error comes back. Any suggestions ??? this is a 1998 accord ex
Old Sep 23, 2004 | 05:37 AM
JimBlake's Avatar
Default Re: Diagnostic error code P1167 (shalemain)
I found a list that says that code is for the heater circuit of the primary O2 sensor.
Since you already changed the sensor, try checking the circuit. I sorta remember that on 1 of the engines, that has its own fuse.
Old Sep 23, 2004 | 08:07 AM
newdad's Avatar
yeah the code is for the primary o2 sensor, is that the one you replaced or did you repolaced the second one.. also is it s a honda o2 sensor... if you already did that then is a wire problem from your o2 sensor to the computer not communicating right check your wires..
924drb20
Dec 14, 2010 10:36 AM
importnoodles
Mar 29, 2008 10:20 AM
b_serious
Jan 26, 2006 05:22 AM
s14hybrid
Nov 24, 2004 05:16 AM
