Caster problem
Old Sep 26, 2004 | 12:29 PM
::MYCORD::'s Avatar
Default Caster problem
Hey guys,
I have been having some trouble with my caster. I hit a curb recently and all hell went loose. I fixed it but the caster on the right side is still off by 2 whole degrees. The wheel is pushed back still. I replaced the lower control arm and the radius rod but it still is hella off. Can you guys think of any other things that can be wrong? Thanks
Old Sep 27, 2004 | 12:07 AM
::MYCORD::'s Avatar
Default Re: Caster problem (mycord)
anyone?
Old Sep 29, 2004 | 01:55 PM
::MYCORD::'s Avatar
bump
Old Sep 30, 2004 | 06:39 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycord &raquo;</TD></TR><TR><TD CLASS="quote">... I fixed it but the caster on the right side is still off by 2 whole degrees. The wheel is pushed back still. I replaced the lower control arm and the radius rod but it still is hella off...</TD></TR></TABLE>Well, then you didn't really fix it. Something's still bent or out-of-place. Possibilities?
1) Proper sequence of washers, bushings, & nut on end of radius rod?
2) Bent mounting points where radius rod is attached?
3) Bent steering knuckle?
4) Bent upper control arm?
5) Bent shock tower where upper control arm is mounted?
Old Sep 30, 2004 | 09:53 AM
Turbowa's Avatar
Default Re: Caster problem (JimBlake)
Easiest way to find out what part is bent would be to take it to a body shop. Tell them what happend and they can put it on a frame rack. This will tell the tech who is working on the car exactly which part is bent.
Old Oct 2, 2004 | 12:01 PM
::MYCORD::'s Avatar
Default Re: Caster problem (Turbowa)
thanks guys i will try that
corpsebesideme
11
Aug 21, 2016 01:11 AM
Untamed_Hatred
Feb 18, 2008 06:41 PM
baiwldrnner
Honda Civic (2001 - 2005)
Nov 1, 2007 09:01 PM
national123
Jun 15, 2007 08:37 AM
essex
10
May 23, 2005 09:41 AM
