Engine Problems
Old Sep 20, 2004 | 07:47 PM
supercreed2002's Avatar
Default Engine Problems
I was driving down a country road and my car died on me and I don't know what to do. I ws thinking either fuel or electrical systems have malfunction. I replaced the fuel pump and Ignition Coil and the car still won't start(Turns over but doesn't kick in). What could be wrong with my car? Seriously experienced people only please!
Caleb
Old Sep 20, 2004 | 08:54 PM
H2290's Avatar
Default Re: Engine Problems (supercreed2002)
Well, first off do you have any check engine lights? That would be a good start. Also check and see if you hear your fuel pump prime when you turn your key to acc.
Old Sep 20, 2004 | 10:13 PM
tjohnson329's Avatar
where do you live at, has it been getting cold up there? If so check your battery voltage it may read good but it could also be your cold cranking amps or cranking amps in general. Try getting a jump to see if that would work. If that doesn't work then it isn't the batter. check the whole starting system
( check to see if there is spark)? ause if you got spark you can then move on.
Old Sep 21, 2004 | 10:12 AM
Default Re: Engine Problems (tjohnson329)
No Check engine light and weather up here is fine(80 degrees). When I turn the ignition on, the fuel pump does run.
Caleb
Old Sep 21, 2004 | 10:13 AM
I haven't checked spark yet, but the engine does crank over.
Caleb
Old Sep 21, 2004 | 06:54 PM
I thought I let you know that I fixed my problem. It happens to be the Igniter in the distributor. It cost me about $81 and 30-45 min. to install. My car purrs like a kitten and can't wait to get it back on the road.
Caleb
P.S. Now I just have to fix the exhaust that was ripped off my car while trying to get it on the trailer!
JdmRex805
19
Nov 20, 2014 05:23 PM
LsHoney84
Jan 17, 2011 06:38 AM
redheadcivic
Jun 1, 2004 11:00 AM
JustinL
Oct 18, 2003 08:16 AM
Hondasaurs
Nov 2, 2002 07:21 AM
