ABS light problem
Old Nov 15, 2004 | 03:18 AM
JDAN's Avatar
Default ABS light problem
Hey, its a 1994 accord, the ABS light comes on and stays on, after about about 10-15 mins of driving. Its strange though because its never on when the car is first started. There is also a strange "buzzing" sound that is intermittent that comes from the drivers side of the engine compartment. I only mention because the sounds is near the ABS module. Anyone have any ideas??
Old Nov 15, 2004 | 07:19 AM
smetzger's Avatar
Default Re: ABS light problem (JDAN)
Your ABS speed sensor may be going. On my 92 Accord these can be reached from the inside of the vehicle. They are located just on the side, just in front of the door.
Old Nov 16, 2004 | 04:19 PM
Morthren's Avatar
sounds like it could be one of the wheel sensors. If a sensor is not working the ABS light will come on to tell you of a problem you will need to take it to the shop so they can read the ABS ecu. The noise is probably the ABS actuator pump running which it will do when the ABS is activated.
Old Nov 17, 2004 | 06:08 AM
JimBlake's Avatar
Default Re: ABS light problem (Morthren)
If you can read ECU error codes, you can read ABS codes. It's the same. You jumper the same connector. Only the ABS light flashes instead of the CEL.
There's a sticky on top of the Integra forum with the flashing syntax for '94-'97 Integra. I bet it's the same for '94 Accord, except the location of the jumper wire is different.
more3688
Apr 1, 2010 12:24 PM
ramz7887
Mar 22, 2007 07:51 PM
Shaun92lude
Dec 8, 2004 07:11 AM
meat
Jul 30, 2003 08:56 PM
