f22b?
Old Jun 12, 2005 | 12:40 AM
crxtuner's Avatar
Default f22b?
WHat are the real advantages of swapping a f22a4 for a f22b besides power? Also what does the accord weigh compared to the civic 2dr?
Old Jun 12, 2005 | 01:11 AM
The_Todd's Avatar
Farts in the shower
Default Re: f22b? (crxtuner)
The f22ax versus the f22b1 is that the f22b1 (94-97 ex) has sohc vtec. The only advantage is that the f22b1 head has vtec and would flow a tad better due to the cam lobe. It depends on the application if you were wanting to go FI or NA on the f22, if you're going FI you are going to see a decent power increase whereas NA you won't see much difference. Honestly it isn't worth the time or the money for the 5 whp if that.
Civic 2dr what? cx, hx, ex, lx, hatch? A little more info on both the accord and the civic for a real comparison.
An accord (4th gen) weighs around 2900-3000 lbs and a civic 2dr ranges from 2300-2800 lbs. (these figures are off the top of my head and are not exact.)
Old Jun 12, 2005 | 01:42 AM
fw190bvi's Avatar
Default Re: f22b? (.ken)
by f22b, i assume your actually talking about the DOHC non vtec accord/prelude motor from long ago in JDM land....its really only worth it if you need a new engine. otherwise the power gains dont offset the cost
Old Jun 12, 2005 | 12:06 PM
240sx crazy's Avatar
so then besides the h22 what would be the next best motor for a 90-93 accord
Old Jun 12, 2005 | 12:26 PM
crxtuner's Avatar
Can anyone help?
Old Jun 12, 2005 | 09:23 PM
crxtuner's Avatar
anyone?
Old Jun 12, 2005 | 09:34 PM
mpxs20's Avatar
Default Re: (crxtuner)
well what i have decided to do over the H22, which i was entirely planning on for awhile is im gonna stick with f22a1, which is unfortunately SOHC non vtec. but what i am doing is taking it all apart and boring it out as much as i can and rebuilding it with all performance pistons, new cam and stuff. that might be an option for you, it should end up giving close to h22 in power, maybe not quite as much, but it was described to me well and i like the idea. just a thought for you
Old Jun 13, 2005 | 12:58 AM
mysterious_2's Avatar
Default Re: (mpxs20)
personally i like the jdm f22b.. i was trying to pick one up but the only place i kno that sells em is japanstarmotor and i guess they are outta business
Old Jun 20, 2005 | 09:07 AM
sexyblack93lude's Avatar
Default Re: (mysterious_2)
you can get them on ebay once in awhile, but make sure its legit and i good motor
Old Jun 20, 2005 | 09:16 AM
AccordMD's Avatar
Default Re: (sexyblack93lude)
the only f22b i saw on ebay today is sellin for $80 and has a bent #4 valve
but ebay is a good place to look i guess
Old Jun 20, 2005 | 11:34 AM
DUKE's Avatar
Default Re: (AccordMD)
f22b is a good engine to boost. It has the cast iron block (unlike the h22s) and lower comression pistons. With minor beefing up (ie, rings, sleeves and pistons) you can easily run 10psi and get good torque numbers with it. And I thinkg thats what Accors are lacking in general. lol
Old Jun 20, 2005 | 03:10 PM
Default Re: (DUKE)
ive actually heard of guys running 10 psi on the f22b daily and not running into problems
grocery_getterr
Jul 26, 2015 09:34 AM
thechoson
Jan 5, 2010 06:09 AM
Regulator
Aug 8, 2009 10:59 AM
C_Rock77
Feb 4, 2009 08:19 PM
StinkyTofu
Jul 17, 2001 10:09 AM
