Jacking Points
Old Jun 13, 2005 | 03:40 PM
nasaalien's Avatar
Default Jacking Points
Other than the four designated jack points, are there any other safe areas to jack the car from using a floor jack? I saw an area in the front of the car near the bumper and radiator of exposed metal frame that looked good but I would like to be sure. Thanks.
Car is a 2003 Honda Accord V6
Old Jun 13, 2005 | 06:43 PM
-Bionic-'s Avatar
Former Sponsor
Default Re: Jacking Points (nasaalien)
That should be fine. I use it all the time. Just make sure to put jack stands on the other two places near the front doors.
Old Jun 14, 2005 | 03:11 AM
nasaalien's Avatar
Default Re: Jacking Points (-Bionic-)
Thanks. Just wanted to confirm that I would not do any damage. Those designated jack points fit nicely into the jack and stands.
Old Jun 14, 2005 | 12:48 PM
Vt4kpwn35's Avatar
<FONT SIZE="15">DO NOT PUT IT THERE!!!</FONT>
I did this and the jack slipped $200 later my frame was bent back into shape. Lucky I didn't crack the radiator.
If you want to jack it up in front... look for a little tow hook. Stronger spot to jack with less chance of slipping.
Old Jun 14, 2005 | 02:22 PM
goowakjai
Guest
Posts: n/a
Default Re: Jacking Points (95cd7)
where should i jack from the rear??
Old Jun 14, 2005 | 04:16 PM
nasaalien's Avatar
ok man. thanks, but there are no tow hooks in the front, just one in the rear. is that really sufficient for jacking up the rear end? looks kinda flimsey. the thing is, if i want to jack up the car and put it on stands, there is no way to jack the car from the designated points and then slip a stand onto the same point. no room.
Old Jun 14, 2005 | 07:26 PM
xbn83's Avatar
There is some metal thing that looks like a hook in the front and the back of my car. I used to jack my car from there all the time, no problem. I have 5 g Prelude. Find something similar.
Old Jun 15, 2005 | 04:34 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nasaalien &raquo;</TD></TR><TR><TD CLASS="quote">... no tow hooks in the front, just one in the rear. is that really sufficient for jacking up the rear end? looks kinda flimsey...</TD></TR></TABLE>The manuals for my '95 Integra & '98 Accord both say that rear tow loop IS the proper center jacking point. I've used it many times. I think the '03 is probably the same but I'll try to remember to look...
Old Jun 15, 2005 | 04:48 AM
patastinky's Avatar
Default Re: Jacking Points (JimBlake)
RTFM!!!!!!!!!
Old Jun 15, 2005 | 07:47 AM
Vt4kpwn35's Avatar
Default Re: Jacking Points (patastinky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by patastinky &raquo;</TD></TR><TR><TD CLASS="quote">RTFM!!!!!!!!!</TD></TR></TABLE>
billybod
Jun 21, 2019 08:29 AM
unrefined7
Jan 21, 2006 09:04 AM
gamby
12
Mar 30, 2004 02:09 PM
WTypeRogerX
Jun 14, 2003 11:25 AM
1hottcivic
Mar 13, 2003 09:14 PM
