removing hub
Guest
Posts: n/a
removing hub
alryte, before u bitch, i kno there has been a post about this, i searched, didnt help...is there a way to get the rotor and hub assembly off the knuckle without a press WITHOUT damaging anything? only solutions i've read were to bang da shyt out of ur rotors and then replace them...
Re: removing hub (goowakjai)
For a 1995 accord, you could rent a slide hammer puller to pull it out.
That's what 2 shops I went to used to try to take it off. But even with the slide hammer, it not always easy. (At one shop, one mechanics had a tough time taking it off with the slide hammer, until another mechanic came over, and put it between his legs and pull and got it off with one try. Mind you, the slide hammer was not touching his legs, he was using this method so the his full weight was on the ground and using his body motion (arms and hips) to pull it off instead of just his arm strength.)
Many times you might have rust or other corrosion which make its tougher, but spray some PB Blaster on the center of the hub to help.
Many others on this forum recommend to have a shop press it out.
SlowPokeEg
01-12-2014 10:31 PM
jdm-hondacura
11-17-2006 05:24 PM
dwjgoblue
09-22-2005 04:14 AM
integra7
12-04-2001 12:41 PM
