speedometer doesn't always work
Old Sep 22, 2005 | 06:48 PM
vedha's Avatar
Default speedometer doesn't always work
A 1990 Honda Accord EX automatic. Speedometer randomly quits working. Is there any way this problem can be fixed? Please give me some suggestions.
Old Sep 22, 2005 | 06:49 PM
fw190bvi's Avatar
Default Re: speedometer doesn't always work (vedha)
does the odometer also not work?
does the tach still work?
Old Sep 23, 2005 | 11:19 AM
deserthonda's Avatar
most likely u got a bad v.s. sensor but try something to diagnose,,,,,,,,,,first off, lets assume the fuse is ok because it works at times,,,,,,,,,go to v.s. sensor, unplug the 3 wires connector there should be a yellow, black and orange wires,,,,,,,.put the key on chk for voltage between yellow and black wire you should have close to 12 v. if no voltage u could have a bad black wire to ground , or a open in yellow wire,or bad fuse # 1 under dash fuse box ,,,,,,,if you got near 12 v.........now chk between black and orange u should have around 5 v.,,if not u could have a problem with the orange wire ,, try this and post results
Old Sep 23, 2005 | 08:14 PM
Ghostyman's Avatar
Default Re: speedometer doesn't always work (deserthonda)
deserthonda is right in that it's probably the VSS (Vehicle Speed Sensor). I had the same problem in a 91 Accord manual. In my case, the Check Engine Light came on. If yours is on, check what code is being thrown -- it should be 17 if the problem is the VSS.
noy612
Jun 6, 2008 09:51 AM
1accord
Jul 28, 2006 12:04 AM
slammedef06
Audio / Security / Video
Dec 19, 2005 07:40 AM
b20_ed
Mar 6, 2004 07:49 PM
